coco_cupra
hello. I'm from spain. can mount the cruise control to my Ibiza Cupra 2001? I handle at home but not as Engo to do. they have to put pins in the ecu?
nobody in this forum as a mounted
? I need to know where the numbers come ecu threads. to enable it put in the vag com 11463.
send me an email, I'll send you the wiring diagram. you just need to push the wire & clip into the ECU connector
I miss having cruise control! not that i used it for fuel efficiency mind you, more for setting a high speed and then slowing down and then switching it back on! :drive1:
hi mi cc not go!!!!!i install the wire blue in brake pedal but where? brake is 2 connectors i have photo. where?, blue conector or white connector?
mi installation is ok but i understand :cry::cry::cry::cry: why?¿? help please
mi installation is here:
help me please!!!!
Parece ser que no les gusta el control de crucero!
Yo tenia un Audi A3 y se lo pusieron muy facil, cambiando solo el intermitente, en 200€ me lo hicieron todo.
Si lo has conseguido poner tu, dimelo porque yo tambien estoy pensando en ponermelo.
Gracias.
