DaNnY_LaD's HTA-Gt2868R Big turbo Build(Now @ AKS Tuning)
Ronin225
4,652
22
Worcester
I ordered a forge supersize for mine in the black friday deal, works out lots cheaper than other alternatives i looked into
I also bought a mk4 R32 throttle body awhile back maybe a cheap alternative over a new TB
I have the part no if you need it
Ronin225
4,652
22
Worcester
You keeping the same inlet mani or going to swap for one with a larger plenum later
Assume that you'll need an adapter plate to fit the TB if its a standard mani
Importantly is this a finished project now or will you keep tweaking and adding to it?
DaNnY_LaD
Big Turbo Leon Cupra R
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
In my eyes its finished but it needs a
Larger dv for sure to flow what's needed.. Shame really as the gfb sounds awesome
And it worked fine on my k04 setup lol
The ina kit is a bolt on application for the standard inlet manifold...70mm is perfect size for what I need :)
DaNnY_LaD
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
First time ever I was actually shocked how rapid it is..
Earlier was just cruising on the motorway @70mph and I seen a mk2 focus rs in the distance ..I felt he wanted a play due to him braking hard and coming up along side me ...
So I pop it gently in to 4th and he went for it...for a brief moment he was in front maybe a car length the something happened I'm not sure was over so quickly...
I was at 130mph and he went screaming backwards... The rs looked nice tbh had a dv which you could hear and a uber loud exhaust and pop and bang..
Bit still I was actually shaking after it... It had a dreamscience sticker on it?
ReDBull
Every day's a school day.
Nov 21, 2006
2,991
14
Lincoln
Sounds like good fun! You do realise the RS drive isn't going to sleep tonight and has already spent £10k more in his head.
Mar 20, 2009
1,707
Largs Scotland
Love seeing those RS's blown away i really can't stand them! I had a play with a standard RS in the 200 when i was down south and could keep up with it so i can only imagine the look on the drivers face after you put the foot down :lol:
DaNnY_LaD
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
Was out boost hard the other night and ever since then my idle is all over the place..drives and boosts fine but feels a tad lumpy and sometimes its holds revs and feels like its hunting for them
No fault codes yet but I had the camshaft a code 16395 but it hasn't come back... Faulty sensor? Air leak? The 007p is on it now too
Some videos of the idle
http://youtu.be/k0bgGB7O7gg
http://youtu.be/QPJNMbhNVaw
t0m
LCR 225
Apr 29, 2007
8,133
7
Kent
Maybe DV?
Surely if it was a boost leak you'd get 17705 up.
Get it to Alex. Hopefully nothing too bad mate.
t0m
LCR 225
Apr 29, 2007
8,133
7
Kent
Even a small split in the inlet mani hose usually throws a 17705.
His car sounds rougher than a small leak though on idle to me. What N75 do you run Danny? Is it the race version?
DaNnY_LaD
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
Finally started to make her look abit better now son started on the small scrathes with the g3 and will mob it once the wings and boot have been done ..
