Yup sure is got loads todo too...But get paid next week :d
few little touches:D new centre caps and stickers...Going awesome as soon as ive sorted out the camshaft sensor.
They the carbon fiber ones like mine mate ? I got the larger set of center caps they fill the whole had to trim the edge down of the plastic part
Lol i know mate...
I had been getting these codes around 3.5krpm....
16727/P0343/000835 - Camshaft Position Sensor (G40): Signal too High
16395/P0011/000017 - Bank 1: Camshaft A (Intake): Retard Setpoint not Reached (Over-Advanced)
So We Re Checked the wireing to the sensor and Re Soldered it and Took it for a drive..Drives real Nice But soon as you let boost build to around 3.5krpm it would slighty Miss...
So re checked via vag com and no codes...Seems i have another Coilpack on its way out Coilpack 4 went a few days ago so im guessing the rest are going....
fitted my Cold Side relocation kit today...Awesome mod for £26 compared to forges one...
havent took a after picture as of yet but only took 15minutes todo and noise is a fair bit louder too on a 007p DV and at only 10psi...havent tryed it up at peak boost yet Need todo more miles..
Ive Been tryin to clock up the miles on the car which is being a real pain todo as i dont know were to go....
Anyway ive been getting a random Miss firer at 3.8krpm when boost is started to rise...Now if only does it if boost is there Eg under Load...So im guessing Coilpack Breaking down under boost?i had this problem last time and it turned out to be a coilpack on number 4....ive bought a new one from GT And tryed it on number 3 and still the same but gonna try the new one on number 1 and 2 see how it is...Drives perfectly fine though..
no fault codes either...
Where did you get this from?
its brand new mate..
you make the kit your self..
2x 90 degree 25mm Bends
1m 25mm Silicone Hose
1x 25mm blanking plug
1x 63mm t-peice with 25mm Spout...
Search through ebay using them titles should come across them...I got the idea of Dan (s1pru) really easy todo.
