Took the Timing pulley off and found these:
But looks fine from the out side:
Unless it should be wider:
Damage Could be alot worse tbh But all id need is timing belt kit,Crank Pulley & Bolts,HeadGasket,Headbolts and i could get a 2nd hand head for £200 off a TT....
But im going to Rebuild my current one with some uprated parts ect....Least Bottom End seems fine..
Everything has been Ordered....
8 X ferrea Exhaust Valves
12 x Ferrea Inlet valves
OEM Headgasket
Cylinder Rebuild kit
Gates Performace timing belt Kit
ARP Head Studs & Tool
Stainless Steel Rocker valve Cover
AEM Uego 6-1 AFR gauge
ARP Crank bolt and Timing pulley...
Currently Discussing a 71R or 76R with Sammy for my car but undesided plus im not sure weather to take the Pistons out and renew with new Rings
Would like to say a Huge Thanks to INA(sammy) for all the parts and excellent service...
Parts should be here within 7 days...
Great list of mods ther Danny. I'm tempted by a set of valves off Integrated engineering but i'm undecided if its worth the cost and i'm waiting to set the outcome of thier mild camshafts too. Looking forward seeing you back on the road.
Anway Back on topic..
Started to paint a few things to de-bling parts and Freshen them up So started with Rocker Cover and Charge Pipe...Used VHT Wrinkle paint which is Awesome i used a Heat gun for Immense Results....
its still drying at the moment so it will even out...
P.s thanks Ash for the paint..xxxx
Nice man, I've been tempted to the wrinkle paint... Looks quality.
Saw a few S3's wrinkled up at U'Dubs today aswel
Lookin good. Be alot better tmoz wen fully dry. Gonna do my inlet mani tmoz with it and try and polish the rocker cover if i cba.
Danny, you will need to get your paint scraper out as youve painted the oil cap, the DV and n75 sealing faces lol
Shouldn't be too difficult to remove.
I bought that paint for my inlet mani and couldn't get a decent finish at all! It just looked really shiny and the paint looked blistered rather than a powder coat effect. I'm guessing there's a knack to putting it on then:doh:
U have to spray it on in different directions. Up and down, side to side, then diagonaly. Did this on my bat cover and looks good, until i tried to put it back on not realising it was still abit soft and put a fingerprint in it :(
