What does plug from cylinder 4 look like?
Cylinder 4 is actually out of spec compared to the others.
Done the Cts and checked the cpilpacks and there reading 12volts with the ignition on and 14.4volts with it running..
Also checked the valves on cyl4 and they held petrol...im going todo a cold compresiion test and see what what....but I do keep blowing my throttle bodie hose off when I boot it..
Was you logging the other day mate? Ashleigh said "Fcuking hell, thats quick.. Hold on, is that Danny" Haahaa!! Orange and black colour scheme looks mint!!
Block 032 shows fuel trims which can be checked with or without the engine running. They should give you an indication as to whether you are running lean or not.
Block 031 shows actual vs specified lambda readings. Multiplying these by 14.7 will give you the AFR.
