Do the door strips just pull off? Any guidance / advive on removing the bits you took off?
mike
mike
mike
On the speaker covers theres a small slot use a flat screwdriver in there, careful not to press too hard and damage the door card.
On the door strips i found it best to start from the end towards the front of the door, theres more of it exposed there. Again i used a flat screwdriver, just use it carefully
Hope this helps.
It easy to break the clips? Mines getting flocked I think![]()
Or you could wrap them
I'll post new photos at a later time when I'll do them with a different brand of carbon fiber wrap. You could also use aluminum brushed look wrap.
No pics
Is it gloss or carbon?
