im really liking the idea of this,forge should have done this a long time ago. i take it the neuspeed one for the audi a3 wont fit then?
Neat job, good pics, Damien.
wow that does look easy,did you put the thread in the pin?
i can see why you havent welded that in place that shifter bracket is nasty metal to have to weld on.
thats good to know. i dont suppose you got any photos of the opposite side of the shifter after the work?
On the pluss side, there is loads of room to do the side to side bracket.
good work!!!!
40% reduction!!!!
how long did it take to do?
how easy was it to get the pin out of the backet?
in an earlier post you wrote:-
did you have to drill this also, how did you get that off?
It prob took about 40 mins to do. Very easy to do if you have the right tools.
Grind off the back of the pin where it is rivited over then knock the pin out with a punch.
The hardest part is actualy getting the cable off the ball/pin. I used a 13mm spannun and put it inbetween the shifter bracket and cable end and forced it off the ball/pin. No drilling required to remove it.
I might try the side to side one next week.
