hello,
had a little problem earlier this evening, my rear right drum made a squeeky sound so I jacked up the car and you could hardly rotate the wheel.
took the wheel of, took the boltcap of (just didn't had a 12 sided nut to go over it... darn or else I could take the drum of as well...)
but then I hit the drum with a hammer (with care...) and lots of black powder/chunkie bits fell out of it
afterwards the wheel rotated much better
that was an emergency fix because I had to get home...
now my question is:
-how can I prevent this from happening again?
-Should I replace the drums/pads?
-If I should replace them, should I also replace the piston assembly (suggested by a dealer, seams quite ridiculous too me...)
is it possible to change it to discs...
what do you need:
-hoses
-calipers+pads
-discs
rear axle is the same (according to etka)
but is it possible?
now my question is:
what do you need:
-hoses
-calipers+pads
-discs
but is it possible?
