Hello All,
Today I removed my egr to see how clogged up it was to discover clogged full with no light through it.
anyways, whilst cleaning the worst out i discovered the shutter plate to be loose from the horizontal arm.
So I know it needs replacing, which got me a thinking:
What are the best replacements to stop the clogging::
1; clean & put back with map to remove function
2; put in a blanking plate with 5 or 7mm hole in it
...which confused me, as surely the soot would build up next to this instead, or does some build up and some go through the hole. Therefore what is the benefit? Some people say they get the CEL & some do not. How can it be different if same thing is applied?
3; straight through pipe
...no anti-shudder flap thing. Is this a concern as some people say it helps the car in turn off and stops over-run and illing it.
4; wing-nut / stealth jobbie, modify the egr to remove the vertical component part
...leaves anti-shudder valve and allows gases straight through
have read so many differing threads i was totally confused.
So, how would one know which is the better way to go?
thoughts & opinions on above and others please.
Need to make decision & purchase on monday as no transport at present.
thank you for reading my ramblings
