Not that I've noticed.
But I'd rather have a little lumpiness than an inlet manifold full of shite.
Hence my CCV bypass too.
See more of my war on the black gunge here
you can just see the little golf tee
just did the blanking plate and the 4mm hoole on mine so touch wood that will stop the engine light coming on while stopping all the shite.
OK I took a log today using VAG COM of what the EGR is doing at idle.
I have done the thing that turns it down using VAG COM and have also plugged the top vacuum pipe going into the EGR saucer with a golf tee so it is disconnected from the EGR.
This is what I logged with the engine at idle
Engine speed 790-870 = 903
MAF Specified mg/R = 350
MAF Actual mg/R = Varied between 411.6 and 441
EGR Duty Cycle = 84.5%
Can someone please interperet these for me as I am no mechanic, but from what I gather it means that the EGR has been successfully disabled?
How did you get those results?
MAF Specified mg/R = 335
MAF Actual mg/R = Varied between 392.0 and 411.6
This is with my EGR vacume hose blocked. Not sure if any of these results are relevant though, i'm doing some reading on the EGR's on TDIClub.
VAG COM
Engine Module
Basic Settings
Group 003
It will increase revs to 1400RPM, start logging.
This is what I got; don't understand why the EGR duty cycles between 64.5 and 19.9???
Code:
Sunday	17	August	2008	19:20:44
038 906 019 KG 		1.9l R4 EDC 0400SG  5342
	Group A:	003
		Engine speed	MAF (specified)	MAF (actual)	EGR duty cycle
	TIME	790-870	230-350	210-370	40-75%
MARKER	STAMP	 /min		 mg/R	 %
	0.54	1218	EGR On	445.9	55.8
	0.94	1218	EGR On	450.8	64.5
	1.32	1239	EGR On	465.5	64.5
	1.72	1260	EGR On	460.6	64.5
	2.12	1281	EGR On	460.6	64.5
	2.52	1302	EGR On	460.6	64.5
	2.92	1302	EGR On	455.7	64.5
	3.31	1344	EGR On	465.5	64.5
	3.71	1344	EGR On	460.6	64.5
	4.09	1365	EGR Off	460.6	64.5
	4.49	1386	EGR Off	475.3	19.9
	4.89	1386	EGR Off	494.9	19.9
	5.29	1407	EGR Off	490	19.9
	5.69	1407	EGR Off	465.5	19.9
	6.07	1407	EGR Off	470.4	19.9
	6.47	1407	EGR Off	504.7	19.9
	6.87	1407	EGR Off	490	19.9
	7.27	1407	EGR Off	480.2	19.9
	7.67	1407	EGR Off	485.1	19.9
	8.06	1407	EGR Off	475.3	19.9
	8.46	1407	EGR Off	480.2	19.9
	8.86	1407	EGR Off	485.1	19.9
	9.26	1407	EGR Off	485.1	19.9
	9.66	1407	EGR Off	490	19.9
	10.06	1386	EGR Off	490	19.9
	10.46	1407	EGR Off	470.4	19.9
	10.86	1407	EGR Off	485.1	19.9
	11.26	1386	EGR Off	480.2	19.9
	11.66	1407	EGR Off	490	19.9
	12.06	1407	EGR Off	450.8	19.9
	12.46	1407	EGR Off	475.3	19.9
	12.86	1407	EGR Off	465.5	19.9
	13.26	1407	EGR Off	499.8	19.9
	13.66	1407	EGR Off	480.2	19.9
	14.06	1407	EGR Off	490	19.9
	14.46	1407	EGR On	455.7	19.9
	14.84	1407	EGR On	475.3	64.5
	15.24	1407	EGR On	485.1	64.5
	15.64	1407	EGR On	494.9	64.5
	16.04	1407	EGR On	504.7	64.5
	16.44	1407	EGR On	475.3	64.5
	16.82	1407	EGR On	504.7	64.5
	17.22	1407	EGR On	490	64.5
	17.62	1407	EGR On	475.3	64.5
	18.02	1407	EGR On	494.9	64.5
	18.42	1407	EGR On	460.6	64.5
	18.81	1407	EGR On	485.1	64.5
	19.21	1407	EGR On	470.4	64.5
	19.61	1407	EGR On	475.3	64.5
	20.01	1407	EGR On	490	64.5
	20.41	1407	EGR On	470.4	64.5
	20.79	1407	EGR On	494.9	64.5
	21.19	1386	EGR On	504.7	64.5
	21.58	1407	EGR On	465.5	64.5
	21.98	1407	EGR On	499.8	64.5
	22.38	1407	EGR On	460.6	64.5
	22.78	1407	EGR On	465.5	64.5
	23.18	1407	EGR On	480.2	64.5
	23.56	1407	EGR On	480.2	64.5
	23.96	1407	EGR On	499.8	64.5
	24.36	1407	EGR On	470.4	64.5
	24.76	1407	EGR Off	465.5	64.5
	25.16	1407	EGR Off	499.8	19.9
	25.54	1407	EGR Off	480.2	19.9
	25.94	1407	EGR Off	494.9	19.9
	26.34	1407	EGR Off	470.4	19.9
	26.74	1407	EGR Off	460.6	19.9
	27.14	1407	EGR Off	465.5	19.9
	27.54	1407	EGR Off	485.1	19.9
	27.94	1407	EGR Off	480.2	19.9
	28.34	1407	EGR Off	480.2	19.9
	28.74	1407	EGR Off	475.3	19.9
	29.14	1407	EGR Off	485.1	19.9
	29.54	1407	EGR Off	475.3	19.9
	29.94	1407	EGR Off	494.9	19.9
	30.34	1407	EGR Off	485.1	19.9
	30.74	1407	EGR Off	485.1	19.9
	31.14	1407	EGR Off	475.3	19.9
	31.54	1407	EGR Off	475.3	19.9
	31.94	1407	EGR Off	485.1	19.9
	32.34	1407	EGR Off	475.3	19.9
	32.74	1407	EGR Off	475.3	19.9
	33.14	1386	EGR Off	465.5	19.9
	33.54	1407	EGR Off	470.4	19.9
	33.94	1407	EGR Off	470.4	19.9
	34.33	1407	EGR Off	494.9	19.9
	34.73	1407	EGR Off	460.6	19.9
	35.13	1407	EGR On	490	19.9
	35.53	1407	EGR On	485.1	64.5
	35.93	1407	EGR On	499.8	64.5
	36.31	1407	EGR On	475.3	64.5
	36.71	1407	EGR On	504.7	64.5
	37.11	1407	EGR On	475.3	64.5
	37.51	1407	EGR On	460.6	64.5
	37.91	1407	EGR On	455.7	64.5
	38.29	1407	EGR On	490	64.5
	38.69	1407	EGR On	480.2	64.5
	39.09	1407	EGR On	480.2	64.5
	39.49	1407	EGR On	470.4	64.5
	39.89	1407	EGR On	480.2	64.5
	40.29	1407	EGR On	470.4	64.5
	40.69	1407	EGR On	480.2	64.5
	41.09	1407	EGR On	494.9	64.5
	41.49	1407	EGR On	494.9	64.5
	41.89	1407	EGR On	490	64.5
	42.29	1407	EGR On	485.1	64.5
	42.69	1407	EGR On	490	64.5
	43.08	1407	EGR On	499.8	64.5
	43.48	1407	EGR On	480.2	64.5
	43.88	1407	EGR On	494.9	64.5
	44.28	1407	EGR On	485.1	64.5
	44.68	1407	EGR On	480.2	64.5
	45.06	1407	EGR On	475.3	64.5
	45.46	1407	EGR Off	509.6	64.5
	45.86	1407	EGR Off	499.8	19.9
	46.26	1407	EGR Off	475.3	19.9
	46.66	1386	EGR Off	480.2	19.9
	47.04	1407	EGR Off	499.8	19.9
	47.44	1407	EGR Off	490	19.9
	47.84	1407	EGR Off	470.4	19.9
	48.24	1407	EGR Off	499.8	19.9
	48.64	1407	EGR Off	494.9	19.9
	49.03	1407	EGR Off	490	19.9
	49.43	1407	EGR Off	475.3	19.9
	49.83	1407	EGR Off	470.4	19.9
	50.23	1407	EGR Off	490	19.9
	50.63	1407	EGR Off	460.6	19.9
	51.01	1407	EGR Off	465.5	19.9
	51.41	1407	EGR Off	480.2	19.9
	51.79	1407	EGR Off	465.5	19.9
	52.19	1407	EGR Off	504.7	19.9
	52.59	1407	EGR Off	490	19.9
	52.99	1407	EGR Off	460.6	19.9
	53.39	1407	EGR Off	480.2	19.9
	53.78	1407	EGR Off	490	19.9
	54.18	1407	EGR Off	494.9	19.9
	54.58	1407	EGR Off	465.5	19.9
	54.98	1407	EGR Off	494.9	19.9
	55.38	1407	EGR Off	490	19.9
	55.76	1407	EGR On	490	19.9
	56.16	1407	EGR On	465.5	64.5
	56.56	1407	EGR On	485.1	64.5
	56.96	1407	EGR On	480.2	64.5
	57.36	1407	EGR On	475.3	64.5
	57.76	1407	EGR On	499.8	64.5
	58.16	1407	EGR On	499.8	64.5
	58.55	1407	EGR On	494.9	64.5
	58.95	1407	EGR On	475.3	64.5
1	59.35	1407	EGR On	475.3	64.5
	59.75	1407	EGR On	494.9	64.5
	60.15	1407	EGR On	485.1	64.5
	60.53	1407	EGR On	460.6	64.5
	60.93	1407	EGR On	480.2	64.5
	61.33	1407	EGR On	475.3	64.5
	61.73	1407	EGR On	494.9	64.5
	62.13	1407	EGR On	485.1	64.5
	62.51	1407	EGR On	490	64.5
	62.91	1407	EGR On	494.9	64.5
	63.31	1407	EGR On	470.4	64.5
	63.71	1407	EGR On	480.2	64.5
	64.11	1407	EGR On	480.2	64.5
	64.5	1407	EGR On	485.1	64.5
	64.9	1407	EGR On	470.4	64.5
	65.3	1407	EGR On	490	64.5
	65.7	1407	EGR On	475.3	64.5
	66.1	1407	EGR Off	494.9	64.5
	66.48	1407	EGR Off	475.3	19.9
	66.88	1407	EGR Off	494.9	19.9
	67.26	1407	EGR Off	470.4	19.9
	67.66	1407	EGR Off	485.1	19.9
	68.06	1407	EGR Off	475.3	19.9
	68.46	1407	EGR Off	470.4	19.9
	68.86	1407	EGR Off	494.9	19.9
	69.25	1407	EGR Off	475.3	19.9
	69.65	1407	EGR Off	504.7	19.9
	70.05	1407	EGR Off	475.3	19.9
	70.45	1407	EGR Off	485.1	19.9
	70.85	1407	EGR Off	480.2	19.9
	71.23	1407	EGR Off	490	19.9
	71.63	1407	EGR Off	475.3	19.9
	72.03	1407	EGR Off	465.5	19.9
	72.43	1407	EGR Off	485.1	19.9
	72.83	1407	EGR Off	485.1	19.9
	73.23	1407	EGR Off	475.3	19.9
	73.63	1407	EGR Off	485.1	19.9
	74.03	1407	EGR Off	470.4	19.9
	74.43	1407	EGR Off	485.1	19.9
	74.83	1407	EGR Off	485.1	19.9
	75.23	1407	EGR Off	494.9	19.9
	75.63	1407	EGR Off	455.7	19.9
	76.01	1407	EGR Off	470.4	19.9
	76.41	1407	EGR On	475.3	19.9
	76.81	1407	EGR On	480.2	64.5
	77.21	1386	EGR On	455.7	64.5
	77.61	1407	EGR On	470.4	64.5
	78	1386	EGR On	494.9	64.5
	78.4	1407	EGR On	480.2	64.5
	78.8	1407	EGR On	470.4	64.5
	79.2	1386	EGR On	490	64.5
	79.6	1407	EGR On	475.3	64.5
	79.98	1407	EGR On	460.6	64.5
	80.38	1407	EGR On	465.5	64.5
	80.78	1407	EGR On	490	64.5
	81.18	1407	EGR On	485.1	64.5
	81.58	1407	EGR On	494.9	64.5
	81.97	1407	EGR On	485.1	64.5
	82.37	1407	EGR On	460.6	64.5
	82.75	1407	EGR On	499.8	64.5
	83.15	1407	EGR On	494.9	64.5
	83.55	1407	EGR On	470.4	64.5
	83.95	1407	EGR On	460.6	64.5
	84.35	1407	EGR On	494.9	64.5
	84.73	1407	EGR On	480.2	64.5
	85.13	1407	EGR On	465.5	64.5
	85.53	1407	EGR On	490	64.5
	85.93	1407	EGR On	490	64.5
	86.33	1407	EGR On	470.4	64.5
	86.72	1407	EGR Off	475.3	64.5
	87.12	1407	EGR Off	490	19.9
	87.52	1407	EGR Off	470.4	19.9
	87.92	1407	EGR Off	485.1	19.9
	88.32	1407	EGR Off	480.2	19.9
	88.7	1407	EGR Off	485.1	19.9
	89.1	1407	EGR Off	475.3	19.9
	89.5	1407	EGR Off	475.3	19.9
	89.9	1407	EGR Off	480.2	19.9
	90.3	1407	EGR Off	470.4	19.9
	90.68	1407	EGR Off	490	19.9
	91.08	1407	EGR Off	485.1	19.9
	91.48	1407	EGR Off	485.1	19.9
	91.88	1407	EGR Off	475.3	19.9
	92.28	1407	EGR Off	494.9	19.9
	92.68	1407	EGR Off	490	19.9
	93.08	1407	EGR Off	480.2	19.9
	93.48	1407	EGR Off	470.4	19.9
	93.88	1407	EGR Off	475.3	19.9
	94.28	1407	EGR Off	480.2	19.9
	94.68	1407	EGR Off	485.1	19.9
	95.08	1407	EGR Off	499.8	19.9
	95.47	1407	EGR Off	470.4	19.9
	95.87	1407	EGR Off	475.3	19.9
	96.27	1407	EGR Off	475.3	19.9
	96.67	1407	EGR Off	480.2	19.9
	97.07	1407	EGR On	494.9	19.9
	97.45	1407	EGR On	475.3	64.5
	97.85	1407	EGR On	494.9	64.5
	98.25	1407	EGR On	494.9	64.5
	98.65	1407	EGR On	480.2	64.5
	99.05	1407	EGR On	485.1	64.5
	99.45	1407	EGR On	465.5	64.5
	99.85	1407	EGR On	480.2	64.5
	100.25	1386	EGR On	465.5	64.5
	100.65	1407	EGR On	480.2	64.5
	101.05	1407	EGR On	494.9	64.5
	101.45	1407	EGR On	475.3	64.5
	101.85	1407	EGR On	475.3	64.5
	102.25	1407	EGR On	475.3	64.5
	102.65	1407	EGR On	485.1	64.5
	103.05	1407	EGR On	494.9	64.5
	103.45	1407	EGR On	480.2	64.5
	103.85	1407	EGR On	465.5	64.5
	104.25	1407	EGR On	485.1	64.5
	104.65	1407	EGR On	485.1	64.5
	105.05	1407	EGR On	514.5	64.5
	105.45	1407	EGR On	480.2	64.5
	105.85	1407	EGR On	465.5	64.5
	106.23	1407	EGR On	460.6	64.5
	106.63	1407	EGR On	465.5	64.5
	107.03	1407	EGR On	480.2	64.5
	107.43	1407	EGR Off	480.2	64.5
	107.83	1407	EGR Off	475.3	19.9
	108.22	1407	EGR Off	494.9	19.9
	108.62	1407	EGR Off	490	19.9
2	109.02	1407	EGR Off	475.3	19.9
	109.42	1407	EGR Off	499.8	19.9
	109.82	1407	EGR Off	485.1	19.9
	110.2	1407	EGR Off	485.1	19.9
	110.6	1407	EGR Off	470.4	19.9
	111	1407	EGR Off	480.2	19.9
	111.4	1407	EGR Off	475.3	19.9
	111.8	1407	EGR Off	475.3	19.9
	112.18	1407	EGR Off	490	19.9
	112.58	1407	EGR Off	450.8	19.9
	112.97	1407	EGR Off	470.4	19.9
	113.37	1407	EGR Off	470.4	19.9
	113.77	1407	EGR Off	475.3	19.9
	114.17	1407	EGR Off	460.6	19.9
	114.57	1407	EGR Off	460.6	19.9
	114.95	1407	EGR Off	465.5	19.9
	115.35	1407	EGR Off	490	19.9
	115.75	1407	EGR Off	475.3	19.9
	116.15	1407	EGR Off	475.3	19.9
	116.55	1407	EGR Off	470.4	19.9
	116.94	1407	EGR Off	499.8	19.9
	117.34	1407	EGR Off	494.9	19.9
	117.74	1407	EGR On	480.2	19.9
	118.14	1407	EGR On	490	64.5
	118.54	1407	EGR On	475.3	64.5
	118.92	1407	EGR On	475.3	64.5
	119.32	1407	EGR On	490	64.5
	119.7	1407	EGR On	485.1	64.5
	120.1	1407	EGR On	490	64.5
	120.5	1407	EGR On	490	64.5
	120.9	1407	EGR On	485.1	64.5
	121.3	1407	EGR On	499.8	64.5
	121.69	1407	EGR On	470.4	64.5
	122.09	1407	EGR On	490	64.5
	122.49	1386	EGR On	460.6	64.5
	122.89	1407	EGR On	509.6	64.5
	123.29	1407	EGR On	499.8	64.5
	123.67	1407	EGR On	475.3	64.5
	124.07	1407	EGR On	490	64.5
	124.47	1407	EGR On	499.8	64.5
	124.87	1407	EGR On	504.7	64.5
	125.27	1407	EGR On	494.9	64.5
	125.65	1407	EGR On	470.4	64.5
	126.05	1407	EGR On	470.4	64.5
	126.45	1407	EGR On	485.1	64.5
	126.85	1407	EGR On	490	64.5
	127.25	1407	EGR On	494.9	64.5
	127.65	1407	EGR On	485.1	64.5
	128.05	1407	EGR Off	480.2	64.5
	128.45	1407	EGR Off	504.7	19.9
	128.85	1407	EGR Off	460.6	19.9
	129.25	1407	EGR Off	475.3	19.9
	129.65	1407	EGR Off	494.9	19.9
	130.05	1407	EGR Off	494.9	19.9
	130.44	1407	EGR Off	480.2	19.9
	130.84	1407	EGR Off	485.1	19.9
	131.24	1407	EGR Off	475.3	19.9
	131.64	1407	EGR Off	490	19.9
	132.04	1407	EGR Off	475.3	19.9
	132.42	1407	EGR Off	470.4	19.9
	132.82	1407	EGR Off	480.2	19.9
	133.22	1407	EGR Off	490	19.9
	133.62	1407	EGR Off	480.2	19.9
	134.02	1407	EGR Off	480.2	19.9
	134.41	1407	EGR Off	499.8	19.9
	134.81	1407	EGR Off	465.5	19.9
	135.21	1407	EGR Off	470.4	19.9
	135.6	1407	EGR Off	460.6	19.9
	136	1407	EGR Off	475.3	19.9
	136.39	1407	EGR Off	485.1	19.9
	136.79	1407	EGR Off	485.1	19.9
	137.17	1407	EGR Off	494.9	19.9
	137.57	1407	EGR Off	490	19.9
	137.97	1407	EGR Off	470.4	19.9
	138.37	1407	EGR On	494.9	19.9
	138.77	1407	EGR On	470.4	64.5
	139.16	1407	EGR On	490	64.5
	139.56	1407	EGR On	465.5	64.5
	139.96	1407	EGR On	460.6	64.5
	140.36	1407	EGR On	494.9	64.5
	140.76	1407	EGR On	480.2	64.5
	141.14	1407	EGR On	480.2	64.5
	141.54	1407	EGR On	499.8	64.5
	141.94	1407	EGR On	490	64.5
	142.34	1407	EGR On	480.2	64.5
	142.74	1407	EGR On	485.1	64.5
	143.14	1407	EGR On	490	64.5
	143.54	1407	EGR On	490	64.5
	143.94	1407	EGR On	475.3	64.5
	144.34	1407	EGR On	475.3	64.5
	144.74	1407	EGR On	455.7	64.5
	145.14	1407	EGR On	480.2	64.5
	145.54	1407	EGR On	485.1	64.5
	145.94	1407	EGR On	480.2	64.5
	146.34	1407	EGR On	475.3	64.5
	146.74	1386	EGR On	485.1	64.5
	147.14	1407	EGR On	465.5	64.5
	147.54	1407	EGR On	494.9	64.5
	147.92	1407	EGR On	470.4	64.5
	148.32	1407	EGR On	470.4	64.5
	148.72	1407	EGR Off	490	64.5
	149.12	1407	EGR Off	475.3	19.9
	149.52	1407	EGR Off	460.6	19.9
	149.91	1407	EGR Off	485.1	19.9
	150.31	1407	EGR Off	475.3	19.9
	150.71	1407	EGR Off	480.2	19.9
	151.11	1407	EGR Off	470.4	19.9
	151.51	1407	EGR Off	494.9	19.9
	151.89	1407	EGR Off	470.4	19.9
	152.29	1407	EGR Off	485.1	19.9
	152.69	1407	EGR Off	465.5	19.9
	153.09	1407	EGR Off	490	19.9
	153.49	1407	EGR Off	499.8	19.9
	153.87	1407	EGR Off	480.2	19.9
	154.27	1407	EGR Off	465.5	19.9
	154.66	1407	EGR Off	465.5	19.9
	155.06	1407	EGR Off	499.8	19.9
	155.46	1407	EGR Off	494.9	19.9
	155.86	1407	EGR Off	485.1	19.9
	156.26	1407	EGR Off	485.1	19.9
	156.64	1407	EGR Off	460.6	19.9
	157.04	1407	EGR Off	470.4	19.9
	157.44	1407	EGR Off	494.9	19.9
	157.84	1407	EGR Off	475.3	19.9
	158.24	1407	EGR Off	494.9	19.9
	158.63	1407	EGR Off	499.8	19.9
	159.03	1407	EGR On	494.9	19.9
	159.42	1407	EGR On	455.7	64.5
	159.82	1407	EGR On	504.7	64.5
	160.22	1407	EGR On	485.1	64.5
	160.61	1407	EGR On	485.1	64.5
	161.01	1407	EGR On	494.9	64.5
	161.41	1407	EGR On	470.4	64.5
	161.81	1407	EGR On	480.2	64.5
	162.19	1407	EGR On	475.3	64.5
	162.59	1407	EGR On	475.3	64.5
	162.99	1407	EGR On	490	64.5
	163.38	1407	EGR On	490	64.5
	163.78	1407	EGR On	485.1	64.5
	164.18	1407	EGR On	490	64.5
	164.58	1407	EGR On	475.3	64.5
	164.98	1407	EGR On	465.5	64.5
	165.36	1407	EGR On	480.2	64.5
	165.76	1407	EGR On	460.6	64.5
	166.16	1407	EGR On	470.4	64.5
	166.56	1407	EGR On	470.4	64.5
	166.96	1407	EGR On	475.3	64.5
	167.34	1407	EGR On	485.1	64.5
	167.74	1407	EGR On	485.1	64.5
	168.14	1407	EGR On	475.3	64.5
	168.54	1407	EGR On	470.4	64.5
	168.94	1407	EGR On	480.2	64.5
	169.33	1407	EGR Off	504.7	64.5
	169.73	1407	EGR Off	485.1	19.9
	170.13	1407	EGR Off	460.6	19.9
	170.53	1407	EGR Off	480.2	19.9
	170.93	1407	EGR Off	485.1	19.9
	171.31	1407	EGR Off	490	19.9
	171.71	1407	EGR Off	490	19.9
	172.09	1407	EGR Off	499.8	19.9
	172.49	1407	EGR Off	475.3	19.9
	172.89	1407	EGR Off	455.7	19.9
	173.29	1407	EGR Off	509.6	19.9
	173.69	1407	EGR Off	475.3	19.9
	174.08	1407	EGR Off	465.5	19.9
	174.48	1407	EGR Off	490	19.9
	174.88	1407	EGR Off	480.2	19.9
	175.28	1407	EGR Off	475.3	19.9
	175.68	1407	EGR Off	480.2	19.9
	176.07	1407	EGR Off	475.3	19.9
	176.46	1407	EGR Off	465.5	19.9
	176.86	1407	EGR Off	480.2	19.9
	177.26	1407	EGR Off	475.3	19.9
	177.66	1407	EGR Off	475.3	19.9
	178.06	1386	EGR Off	485.1	19.9
	178.46	1407	EGR Off	475.3	19.9
	178.85	1407	EGR Off	480.2	19.9
	179.25	1407	EGR Off	480.2	19.9
	179.65	1407	EGR On	485.1	19.9
	180.05	1407	EGR On	490	64.5
	180.45	1407	EGR On	465.5	64.5
	180.83	1407	EGR On	485.1	64.5
	181.23	1407	EGR On	485.1	64.5
	181.63	1407	EGR On	494.9	64.5
	182.03	1407	EGR On	475.3	64.5
	182.43	1407	EGR On	485.1	64.5
	182.81	1407	EGR On	485.1	64.5
Infact reading those results again shows my EGR turning on and off. I suppose doing these logs with the EGR vacume blocked won't give me proper results.
So is our EGR blocking actually working then?
Or is the EGR still functioning?
Very good question, from what I have read tonight some bloke is saying the PD EGR system works on electrical sensors/solenoid system and not using a vacume system.
But I don't see any wires going to the EGR so this may be complete twoddle.
I would be interested to see you log block 003 via the 'basic function' button.
I'm going to read into this, but my head is too knackered to understand anything tonight. Maybe someone on here may read this and give us a understandable explanation.
With the EGR vacuum hose disconnected and blanked off the EGR valve will stay closed. So it's not actually working.
However, you're using Vag Com to read the ecu which is still ordering the EGR to operate as required and that's the readings you're getting in Vag Com logs. The ECU is still telling the EGR system what to do but the system doesn't operate.
There's an electrical connection to the 2.0ltr EGR valve assembly but it's purely for the anti shudder valve system (closes the flap valve on shut down to stop engine shudder), possibly the same on the 1.9 aswell.
Yep correct, the ASV connector is behind the big silver cap for the EGR, look behind and down a little, theres a connector there which attached to a clip on the side of the egr valve.
I run an allard EGR replacement I get shudder on turn off (almost un-noticabe though) and the emission light comes on sometimes. When measured at MOT my emission have actually gone down.
I had a performance gain of 5BHp according to dyno. Plus I gained on average 2mpg on a long run. My EGR valve was a mess almost half the diameter was clogged full of crap.
