neill20v
had my m8 stick his vagcom on my car and got a few codes come up
16706 engine speed sensor (g28) no signal
p0322-35-10---intermitent
16487 - mass air flow sensor (g70): signal too high
p0103-35-10---intermitent
17967 - throttle body (j338):fault in basic settings
p1559-35-00--
17973 - throttle actuator (j338): lower stop not reached
p1565-35-00--
17913 - throttle idle switch (f60): does not close or open circuit
p1505-35-10---intermitent
01259 - fuel pump relay (j17)
31-00- open or short to ground
readiness: n/a
the throttle ones im not to concerened about, but would like some advice, the fuel pump one, would this cause intermitent jerking of the car. it can run perfect for ages then all of a sudden it will chug a few times, more so when putting foot down
thanks for anyhelp
what a waste of a fooking time this forum is, not one reply from any of my threads.
cheers for the help and advice guys, very much appreciated:censored::censored::censored:
Not a good way to get answers. You have to wait for someone who knows about your faults to get any worthwhile advise. Try some patience next time instead of the attitude and you might get somewhere.
bloody hell i got a reply, so there is life out there after all[B)]
Hi
Had similar problem with my 20VT jerking when accelerating - traced it to the plug on the Mass air flow meter being a very loose fit sending wrong elec signal to ECU. Fitted a long cable tie around plug to hold it tight and have not had any problems since. As I do not have access to the Vagcom unit I do not know if it would have shown the faults you have.
