Fault code, Secondary air pump
john.waterman
Having searched the forum, i can find several references to a secondary air injector but none to a secondary air pump, are they the same thing?
i keep getting a engine managment light coming on, and a diagnostic check came up with the secondary air pump, the car still ran fine.
the pump has been removed and is F**ked, i can get a new one from a dealer for £600 or from eurocar parts for £300. if it is the same as the SAI i could just get a blanking plate from forge and save myself a few hundred quid?
what do i need to do?
adam cupra 20vt
Built Not Bought.
Mar 31, 2005
6,162
Mud Hut
Secondary air injection unit? thats the same thing.
Whats wrong with the pump?
Rivetts failed and its in 2 bits?
If so can be fixed for under £5 as I did mine.
Or you can remove it and blank the inlet off.
john.waterman
it looks like it siesed up and now inside it looks like its full of rust particles
adam cupra 20vt
Built Not Bought.
Mar 31, 2005
6,162
Mud Hut
Well your choices are..
Buy a new one
Buy a second hand one from scrappy or ebay etc
Remove it and buy a blanking plate from Forge [about £18 I think] although with the blanking plate I think you might need a resistor in the plug to stop the light keep coming on.
I think Philc has removed his so might be worth a PM to him.
john.waterman
i think i'll just get it blanked off, if it is fine without it i might as well.
