Fitting a Pioneer f910bt
DannyN
70
You have to keep turning bluetooth on and off then, I just wondered if they did a hardwired bit
Apr 4, 2011
572
woodford green
i have one of these
it plugs in the back of the head unit and you hide the box under the dash & run the mike wire up the A pillar
once you have added the phone it works as soon as you turn the head unit on , i fact the other week i was mid call as i started the car and it swtched over and went hands free almost instantly
Apr 4, 2011
572
woodford green
Did you go for that one in the end? My Mrs car now hs dodgy reception and I'm guessing its the antenna base that needs replacing. This looks nicer than stock but don't want to create a fitting project for myself?
no i didnt because that one is not amplified , but was at my mates car audio place yesterday , with the mrs car and he had amplified ones , this is what he had http://www.celsusice.co.uk/shopdisp_5799.php back there the end of the week so will asking him about it more info then
mm
Apr 4, 2011
572
woodford green
right sunny day nice day to fiddle a bit
go the fin as described above that is a trade price btw so it cost me a tenner more !
so pulled the head lining down
and a 19 mm socket did the job
the aerial connecter is clipped at the back of the car
unclipped that and the old one was out
new one the nut is 22m :think: but the 19 mm had the same inner thread so i was able to use that and do it up finger tight as the wires come out the middle of it & then use a adjustable spanner to tighten it up
and yes the car need a wash !
reception is much better that the previous one and looks much better ?
head lining is held in with 2 clips that use the usual seat method of fixing ( thump it ) i did end up with a small crease in the head lining hey ho whos looking !
MM
neilmac
Just starting to tweak...
Jul 12, 2006
294
What is the second wire on the new fin, that doesn't exist on the old antenna?
Ah..12V for the amplification...in which case that one off ebay will go on just fine..with the fakra connector but its not amplified and neither is the stock one by the look of it.
Apr 4, 2011
572
woodford green
yes and no
yes it is a 12v supply but you only use it if you dont have a 12v feed up the aerial lead , from the head unit
so i didnt need it
mm
neilmac
Jul 12, 2006
294
correction its an earth ! there is an extra bit that goes in the head unit end to send 12 v up it and that is the earth for that
So...the last piece in the puzzle..is the stock one (factory fit) active then and amplified or is it passive?
neilmac
Jul 12, 2006
294
stock head unit must have the feed built in i guess ?
Possibly or there is an inline amp back there...but you've removed your head unit haven't you - so guess there isn't an inline one. Tempted to get a new head unit now...as well... :D
