You have to keep turning bluetooth on and off then, I just wondered if they did a hardwired bit
Does that Kenwood unit have a mic for the iphone ?
not yet but i am going to run the sub in for a couple of weeks so maybe thenNice neat build that mac! does the false floor vibrate at all with the sub under it?
so would this go straight on ?http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=220768183813&ssPageName=STRK:MEWAX:IT
no i didnt because that one is not amplified , but was at my mates car audio place yesterday , with the mrs car and he had amplified ones , this is what he had http://www.celsusice.co.uk/shopdisp_5799.php back there the end of the week so will asking him about it more info thenDid you go for that one in the end? My Mrs car now hs dodgy reception and I'm guessing its the antenna base that needs replacing. This looks nicer than stock but don't want to create a fitting project for myself?
mm
What is the second wire on the new fin, that doesn't exist on the old antenna?
Ah..12V for the amplification...in which case that one off ebay will go on just fine..with the fakra connector but its not amplified and neither is the stock one by the look of it.
correction its an earth ! there is an extra bit that goes in the head unit end to send 12 v up it and that is the earth for that
So...the last piece in the puzzle..is the stock one (factory fit) active then and amplified or is it passive?
corroded but amplified !
Possibly or there is an inline amp back there...but you've removed your head unit haven't you - so guess there isn't an inline one. Tempted to get a new head unit now...as well...stock head unit must have the feed built in i guess ?
