Fitting Leather Seats From Toledo 2.3 V5
Fl@pper
Jun 19, 2001
12,366
24
Gloucester
leonlad said:
dont think they will fit the new leon
moved ;)
your dealer can supply a seat motor at about £50 a side for the motor wiring but thats just the start of it to be honest - take a while to get too
the heating system is seperate again and the side airbags again seperate and the rest of the wiring involves more looms/relays/connections to the fuse box
not easy but thee not impossible really - best get a look at the wiring diagram to explain it easier - ask ya dealer for a copy - but ask nicely ;)
Fl@pper
Jun 19, 2001
12,366
24
Gloucester
just the heated seat looms alone on mine were made up of 4 seperate looms at £30 each mind
so
take 1 diagram
add research and a list of part numbers to order
and a selection of correct amperage wiring
add the plastic blocks needed (genuine)
clip in the pin connections (genuine)
solder wires as per diagram and check/secure all
connect and test
VOILA - same thing for £35 ;)
100% made up of money/time/skill is all thats needed
i was skint so i went for options B & C
Fl@pper
Jun 19, 2001
12,366
24
Gloucester
Arctic said:
So is Leon to Leon an easier swap then? As it was 4 torx screws holding the seats in my 306!
May do it in the future
bolting em in is easy but wiring is the same hassle and same parts
advantage is if you have access to the car the seats come from GRAB the looms too :D
Fl@pper
Jun 19, 2001
12,366
24
Gloucester
same way as i usually go then - the hard way :)
don't panic or try and do it all in one go - you'll get there
(says a man who's had his car in pieces for the last 3 weeks) :p
Toledo_130
sorry for digging up an old tread 4 years later... BUT
im in the same situation with the same seats only im fitting mine to a toledo with manual movement at present..
did you ever get the seats workin SHADY-NINJA??? im also only lookin the electric workin (not worry about the heating etc but if its handy to get workin il try it)
the drivers seat has a memory setting, can this be made to work as there seems to be a ecu under the seat..
SHADY-NINJA
993
London
www.airconmedic.co.uk
sorry did someone try to wake me...............................,
SHADY-NINJA
993
London
yes i did.
i spent a further £250 to strip the foam, contuors and leather off the v5 seats thereby reducing it to a skeletal bare shell.
then i had my seats stripped and reduced to bare skeletal shell retaining my airbags.
then the contours, foam and leather were transfered to my frame then it looked like this........,
Toledo_130
you basicly you put the leather and foam onto ur orginal seat base as you wanted the airbags to work properly..
never actually thought about the airbags..
btw wot did you spend 250 on?? my full interior only cost me 150 and its mint, not not to have to spend another 250
SHADY-NINJA
993
London
I spent that £250 on labour alone coz i want it to be perfect with no warning airbag or management lights flashing on my dashboard.
