Fitting Mk4 Curpa front + back bumpers
Jan 14, 2005
1,308
Cannock/Wolvo
How easy is it to install the Mk4 cupra front and back bumpers on a FR? iv just recived the bumpers and grills from dave @ IMG (Thanks very much) im just wondereing if anyone has a guide to fit them???
Also can the screws off the existing bumper be used for the new? or will i need to by all new fixings
Ant FR
2,861
Kent
use all the old screws, you will need to improvise on a couple like the fog light covers and toeing eye cover.
Its a piss of piss to do though. The only hard bit is geting the grill into the front bumper without breaking it or scratching your freshly painted bumpers.
Jan 14, 2005
1,308
Cannock/Wolvo
does the grill on the front go in before you fit the bumper or after???
Ant FR
2,861
Kent
before, oh and do't forget to remove the retainer strips ( the bars that run wher ethe grill should go.
Jan 14, 2005
1,308
Cannock/Wolvo
What about the piece with goes on the back bumper that holds the number plate, do you fix that the the back bumper before you fit it or after the bumpers on??
Ant FR
2,861
Kent
thought it was all part of the bumper, never saw mine come off at all. so not sure what you mean
Jan 14, 2005
1,308
Cannock/Wolvo
its the black section which holds the number plate and reflectors, not to worry iv figured it out now it just clips into the actual bumper its self.
Snoopcousins
Working the Guns!
Mar 18, 2005
564
Bangor
I have just had the Cupra front bumper put on my FR......
I thought the Centre grill was a greyish colour (the same as the greyish Cupra side inserts) which is different to the FRs....maybe im wrong.
(Is this why some think the FR side grill inserts dont look good on the Cupra bumper because they are too black....?
tigor
197
Glasgow, Scotland
All 3 grilles on the Cupra are silverish. I stuck to the standard S grille (later replaced to debadged) and the 2 FR ones. Colour matches that way.
ibiza_fr_james
61
Chandlers Ford
i have been trying to remove the lower grills on the fr bumper, but they still seem atached. i have removed the two screws holding the centre piece in, but whats holding the two outer lower grills
hope some one can help
