what colour spring do you use? probally quite a strong one looking at your sig.
i'll need to try the pressure test at the weekend as i just fitted my 007p (with green spring that looks a bit worn - not much green paint left on it) and Jetex cone last night and it's dumping well but on throttle i'm getting a constant air leak sound when the turbo is spooling
i've never heard another LCR with this setup yet and i know you will hear the turbo spool more with an open cone filter but it just doesn't sound right to me
cheers Si that would be spot on, i'll test it on sat and go from there
leon cupra r - by doing that i take it that would just tell me that the spring is at fault ?
i actually got a yellow spring with the DV aswell so i might try that out first (after pressure testing it), the yellow spring looks pretty worn aswell (hardly any paint on it but i was told the DV is no more than 6 months old so i'm not sure if it's just a common problem with the paint coming off on them and they should be fine)
