Forge Side Mount intercooler... is it really worth it?
antzleoncupra
227
Billericay
Found a cheapish Forge side mount intercooler, is it really worth buying one, or the difference from oem wont be worth it? Its 27 mm x 5 mm x 15 mm bigger than the OEM cooler.
Pressure loss reduction: 2psi
Air temp reduction: 6-9 Deg.C
what do you reckon? im aiming for 230 hp with a Forge TIP, 007p dump valve, stage 1 map, decat. Will that intercooler help?
jamiebennett81
no
its cheaper to go with an ebay front mount or save up for a proper FMIC
EDIT - Technically it will help, but you can get better intercoolers for a similar price
traumapat
Leon Cupra IHI
Jul 24, 2005
5,925
sunny sussex
The problem with the side mount is the lack of air running over it, so if you go for it cutting some kind of grill in the wheel arch behind it will give better flow.
FMIC will give much better results full stop.
