front and rear fogs just stopped? fuse location?
05'LCR Dan
went out the otehr night in the car and front and rear fogs just didnt work, tried a search but seems this problem has never come up. For now i just want to find out the location for the fuses?? PLEASE HELP!!! ITS SNOWING AND FOGGY THE WHOLE TIME!!:cry:
robcool
still singing in the rain
Sep 4, 2008
76
retford
The fuses are on the side of the dash, Open the drivers door and on the dash there is abit you need to pull off you will see and little bit to but your screw driver in to help get the panel off, easy enough. All the fuses are behind there!
good luck!!
05'LCR Dan
Got some fuses last night it was the fuse in the end, as u said 36, cant fathem out why it went, all fogs are still working ok? Cheers for all your help.
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
Current spike from the start up procedure at a guess.
what size fuse is it running on the circuit ?
05'LCR Dan
Its funny dan, as they went on it again on Saturday! It was when I had the lights and fogs on without the car started when it went! Weird :)
I will speak to some one at work tommorrow, but i know this much.
When you have a motor on a circuit, you have to put in a different sort of fuse (circuit breaker speaking from an electrician point of view) because the motor inisially requires more current to allow it to start and then once its moving the current drops.
Im not an auto electrician but its based on a similar theory, the motor will be the engine starting and maybe with draws current and when it returns to normal just trips.
Dont take my word tho as i say im not an autoelectrician :blink:
05'LCR Dan
No definately not 100w. Maybe one of the ballasts is on the way out.
I bought the same kit for dipped beam and foglights from hids4u, not sure of the wattage but 100w arent for road use and i know i never got illegal ones.
Ile check it out.
