gear box oil and intercooler
osorabjee
hi. can anyone tell me the interval change of gearbox oil on the 130 pd sport or is it a sealed unit?
I also noticed an oily patch around one of the inercooler pipes today and looks like this. is it diesel oil?
Nath.
The Gentlemans Express
Jan 1, 2006
8,619
16
EASTLEIGH, HAMPSHIRE
pic no worky
oily patch under intercooler ?
have you had your AC/climate on over the last few days as you can get condensation that dripps off of the cold AC pipes in that area
I've also seen other threads about this
air121005
1,609
Worcestershire
i've had a trace of oil around the bottom hose joint on the intercooler. (SMIC :whistle: )
thought this was caused from the oil vapour from the rocker cover that is linked back into the intake, goes through the turbo and then settled in sludge form in the intercooler :confused:
seem to remember reading a thread on it somewhere? :shrug:
osorabjee
For some reason i cant load the pics up???The build up of the oil is only on the joints between the aluminum and rubber pipes running from the turbo to the intercooler.
What about the gear box oil interval cahnge on the 130pd?
Nath.
Jan 1, 2006
8,619
16
ahh right oil vapor and black shite in the intercooler is not much to worry about, most pd130's have this
the problem is that the oil/muck is leeking from the intercooler hose joints, this tells me that the joints are not air tight and that you are prob loosing boost too
gearbox oil normally is not changed unless you have a major problem with the box, sometimes a top up is needed after very high mileage
osorabjee
Wow thanks. I have now been able (figured out) how to get the pics up so will try it once more for good measure and see what you think. What can i do about the leak?get new hoses or are there O rings in them?
osorabjee
Top pic is off the turbo and bottom is off the inercooler but its the same line of pipe.
gazjones
those joints are push fit held with retaining clips. my 20vt has one of these joints and the o ring has perrished and has black gunk around it. try disantling cleaning and replace seal if needed
Nath.
Jan 1, 2006
8,619
16
you can get new O rings for inside the joints or just replace the pipes as they come with new joints AFAIK
even the new pipes are quite cheep, my brother got the top intercooler one for £20
osorabjee
Any ideas where to get the O rings from? not 100% sure of the size but could get a caliper on them. would the intercooler be full of oil if it is coming from the pipe?
Nath.
Jan 1, 2006
8,619
16
get o rings from seat dealers or source your own if you like
the intercooler will have a small amount of oil in the bottom of it maybe an egg cup full, don't worry about it, it is quite normal
oil vapor from the breather pipes at the top of the engine route into the inlet so that they can be burnt off and be disposed of through the exhaust, trouble is the vapor tends to collect at the bottom of the intercooler
spose it's better than making a puddle on the floor
gazjones
the part no. for the seal going on to the turbo is 3c0 145 117
and is the second pic the other end of the hose coming off the turbo?
osorabjee
First pic is from the turbo to the intercooler and second pic is the same pipe but on the join before the intercooler. So it goes...
Turbo, join (leak), rubber pipe, join, aluminum pipe, join onto rubber pipe again (second leak) intercooler.
If you can understand that!!lol.
gazjones
second leak the o ring is part no. 6Q0 145 117
this is joint with the intercooler
