CupraRAlderson
Hello
I have a 2004 Leon Cupra R 225.
The handbrake light has started flashing randomly with 3 beeps. It seems to do it when i go around a bend or touch the brakes. I have checked the brake fluid and it seems ok!
I also have a problem with the clutch. When you 1st push the clutch peddle down it stays at the bottom! If you lift it up with your toe and then pump it a dozen or so times it works fine. But then whilst driving if the clutch hasnt been used for a while the problem comes back! It also does it when driving quickly and racing through the gears.
Are the two problems combined and does any1 know what the problem(s) may be?
Alderson
common question mate, search for 3 beeps would have confirmed the brake fluid.... top it up and it will go away.
also maybe time to get the master cylinder bled and clutch mate.
guarentee top up on fluid will stop it beeping
Thanks for your fast reply mate. I will check the fluid again then get the car to a garage for the clutch problem. Cheers
