Hi all,
Bit of background- I had a slight blow in the flexible section in the downpipe which got quite a bit worse (sometimes causing the engine to missfire until it was warm) so I bought a new downpipe and cat and fitted them, hoping this would solve the problem. They seem to fit fine and be sealed when the engine's running. I've obviously put the lamda sensor back in to the new cat section and didn't use exhaust paste while fitting them.
Got a new problem with my Leon 1.6s (16v - AZD engine) now - it seems to drive fine as long as the revs are kept below about 3k but going any higher than that results in a buzzing noise from the engine compartment and a major loss of power. I've not noticed any loss of coolant but there was a lot of steam from the exhaust when I started it up this morning. There's a little bit of "mayo" on the underside of the oil cap but it's not been driven much recently and not done any long trips.
I've got a couple of warning lights on in the instrument cluster:
Am I right in thinking this is looking like a head gasket failure?
Using my fault code reader (http://www.gendan.co.uk/product_GDVAG.html) the following codes seem to be logged:
and under ATS dtc02
Here's the general thread on the problem: http://www.seatcupra.net/forums/showthread.php?t=202070
Can anyone shed some light on what the fault codes mean?
- 16684 Random Misfire Any Cylinder or Random/Multiple Cylinder Misfire P0300
- 16685 Cylinder 1 misfire detected P0301
- 16687 Cylinder 4 misfire detected P0303
- 16688 Cylinder 4 Misfire detected
- 17961 Barometric/Manifold Pressure Signals Impausible Correlation p1553
- 16708 Knock regulation Malfunction P0324
- 17912 Intake Ais System Bypass Air determined or Intake Air system leak detected p1504
and under ATS dtc02
- 01314 control module in instrement panel on Comfort CAN (J285) twice
