help removing map sensor
fahafiz
231
dear Seatlings... i require help removing a map sensor from a Seat Leon... how on earth do i do it?
Feel
Veedubya 'velle
Jun 12, 2003
4,918
Midlands
Undo the two torx head screws and pull it out.
If the screws are just spinning, the screws have rusted into the inserts and the inserts are just spinning in the pipe. You've need to grind/cut the heads of.
fahafiz
231
i cant undo the screws as theyre hard to get to.... do i need to remove anything...
