Hoses and fixings
tripdiesel
Leon Cupra R 225
Mar 21, 2009
162
Isle of Wight
When i do the N249 bypass, i want to upgrade my hoses to red silicone, i have the hose already but im struggling to find somewhere to buy t-pieces. Also is it best to get jubilee clips or use cable ties, are they strong enough?
adam cupra 20vt
Built Not Bought.
Mar 31, 2005
6,162
Mud Hut
Use a brass T piece as plastic will turn brittle from the heat.
You will need a 6mm brass T piece for 4mm silicon pipe.
Cable ties are fine for this sort of thing....jubiliee clips are overkill for a 6mm T piece and are not needed on vacum lines :)
I'd only use jubilee clips on pressured hoses.
rikwheeler
131
Lincoln
www.rikwheeler.com
Can you get mini clips to use on the 4mm vacuum hoses? Could do with getting some more of those one use clips that are standard on the car. Does anyone know where I can get them from?
