How big is to big for a turbo?
Andrew@ALD
It seams to me that most of the time you can bolt a GT30 turbo to a S3 engine with only some small internal modifications, I'E rods, valves, and valve spring kits.
At what stage do you have to do more internal work when a bigger turbo than a GT30?
Don't plan to do it myself
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
18
glos.uk
aside from full engine balance on build.. mine is the parts listed, but has cams and ported head, fluid damper crank pulley + gt35
you have named th main engine parts
associated running gear will need attention with big power
Andrew@ALD
What power is your engine making on the GT35?
westallc
132
it is very very very very fast the lap before it blew up was eyeopening
i have been to alot of racing and that was one of the fastest cars i have seen going around castle coombe
wheelspinning all the way down the straight lol
Andrew@ALD
Wheel spin?
I wouldn't have that problem in my S3 lol ok i may have a bit if i had that sort of power
ibizacupra
Jul 25, 2001
31,333
18
glos.uk
power is >600bhp, and torque was >480lbft when it flatlined the dyno (pegged it).. so although i dont have an actual figure, more than i have traction for is a given... all gears spin up in the dry at will on full 35psi boost.. 4th span up slightly when on 15psi actuator boost.
lovely spool.. great turbo
ryan_s3
1,270
For the op;
If your still 1.8 then i'd go for gt3071r, if your 1.9/2.0 then gt3076r.
ibizacupra
Jul 25, 2001
31,333
18
glos.uk
head gasket expired..
excessive cylinder pressures from too much timing... and denso plugs shed their ceramics also damaging the valvegear.
no pinking, so that alone is no guarantee that cylinder pressures are becoming excessive.
33 degrees of advance and 35psi boost, no pinking, but too much internal pressure.
INA
Garrett Super STAR!
Dec 8, 2007
www.inaengineering.com
Do you think this is what caused the H/G issues? As ive heard storys of people having the same issues as with these studs you have to check the torque ever so often?
As neither of them are stretch bolts
We just had a set of Raceware's mushroom on us...
makes the $165 USD replacement from ARP's look SOO MUCH more appealing.
