TDiCupraChris
You have been dieseled!!!
Oct 19, 2008
56
Bournemouth
Hi Guys
I need to replace one of my front side grills, how do you go about doing this, does the whole front bumper have to come off or is there another way?
Here is a pic showing the one I need to replace, the small plastic grill that is next to the head light, in between the centre grill and head light, I haven't got a front picture of my car yet, so I used a differant pic just to illustrate.
Many Thanks
Chris
i just replaced them grills today, you dont have to take the whole bumper off, it may be easier but i dint. i found you pretty much have to break the current grills you have to get them out as there is quite a few clips holding them on
So after you break the current grill to get it out, does the new grill and clips slot in ok without having to break the clips off the new one?
yeah its quite hard to get them out but puttin them back in is so much easier they literally just push on just annoying getting them out
all i did was open the bonnet, remove the four torx screws holding down a plastic piece across the centre grill and both side grills just to give it abit of freedom to move and then using a flat screwdriver just levered them out, hope this helps ya :)
what i did when i was fitting my fr ones i undid all the top screws etc and then basically pulled that big plastic bit forward as it is quite flexible then broke all the clips from behind.and yanked the old ones out
mine where also glued.
then fitted the fr ones
