Thanks,
My Leon doesnt have cruise control, though I presume the same problem still applies.
Really annoying that all brake lights stop working. You'd have thought they'd run on seperate circuits for safe driving.
I have around 2 weeks of warranty left. This should be covered by them surely?
Thanks for the reply. I'll try and get it booked in ASAP.
Glad to see its still helping![]()
Eerhh ?!? Why did you all disassemble the complete dash / panels for this job ??!??
The switch is almost in plain sight !
( what do you think these inspection holes in the lower panel are meant for ? ...)
I Just replaced my switch ... in 10 seconds max.
My manual :
Put your head down and look under dash at the brake pedal ,
remove old switch by twisting left. Insert the new one and twist right ...
Done
I took some pictures while changing my switch, see below.
I can also confirm that the green colored 1C0945 511A RDW switch is the (currently)
correct part, superseding all other 1J0 945 511 [#] switches (where # = A to E)
Just be aware that the new 1C0945 511A RDW is selfadjusting in the opposite
way as the older switches! The older switches had to be installed with
the brake pedal down. This switch is simply installed with the brake pedal UP.
I did it wrong first and noted that once once the switch was locked (by twisting it in place) ,
the brake pedal wouldn't travel back up all the way ....
This results in apllied brakes while driving and a very short travel of the pedal ...
