Yeah if I say I'll meet you at Morrisons carpark [roundabout end as its less busy] at 4pm?
Let me know by mid morning tomorrow if you can't make it or if you got it sorted so I know what I'm doing :)
Ok mate, nice one. Not too familiar with beccles though, got a postcode for the morrisons?
Its on the main road, coming from Norwich go straight over the McDonalds roundabout and its just off the next roundabout on the right......can't miss it :)
Postcode NR34 9EJ
Best thing would be to reset them and drive it till the lighht comes on again then see what code it is a I expect all 3 didn't come on at once.
17608 - Boost Pressure Control Valve (N249): Mechanical Malfunction
07705.......are you sure thats a code?
17545 - Fuel Trim: Bank 1 (Add): System too Rich
I have a VAG code reader that tells you the code and the sheet that tells you what the faults relate to.
Its 17705?
17705/P1297/004759 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
Possible Symptoms
* Power Loss
Possible Causes
* Leaking hoses and/or pipes between components
* Check Boost Pressure Control Valve (N249)
Possible Solutions
* Check hoses and/or pipes between components
* Check / Replace Boost Pressure Control Valve (N249)
* Check / clean Throttle Valve, do Throttle Body Alignment
Special Notes
* Did anyone fitted an extra (wrong) dump valve?
Its 17705?
Possible Symptoms
* Power Loss
Possible Causes
Possible Solutions
Special Notes
My bad! Yes 17705. My idea is
Remove the N249 and replace the dump valve for a forge version. Would this get rid of those codes?
Not sure what to do with the last one though, is replacing the maf a step in the right direction?
From reading the Rosstec bit above the first 2 look related?
Has the N249 valve been bypassed? if not you could try bypassing it?
The 17545 could be another fault?
17545/P1137/004407 - Fuel Trim: Bank 1 (Add): System too Rich
Possible Symptoms
Malfunction Indicator Light (MIL) active
Possible Causes
Mass Air Flow (MAF) Sensor faulty
Fuel Pressure Regulator faulty
Fuel Injector(s) faulty
Oxygen Sensor Control faulty
Oxygen Sensor(s) faulty
Evaporative Emission (EVAP) System faulty
Possible Solutions
Check Mass Air Flow (MAF) Sensor
Check Fuel Pressure Regulator
Check Fuel Injector(s)
Check Oxygen Sensor Control
Check Oxygen Sensor(s)
Check Evaporative Emission (EVAP) System
It might do....I have a standard Bosch valve you can try if you like?
My MAF went last week and the fault code was 16486
