in need of info about n249 valve bypass
adamash24
hey folks! im running a mk1 leon 20vt, got a slight running problem, in neeed of advise.....
i've changed afm n75 valve, heard of n249 valve by pass, can anyone give me step by step instructions on how to carry this out! and feed back if it cures the fault. :confused:
looking forward to hearing some positive feedback cheers
mrwookie
Big Daddy...
Mar 22, 2008
716
Cambs & Herts
Hey bud 2 easy ways to bypass the N249.
First being to remove the feed which comes from the under side of the inlet manifold and then extend to the top off the DV or the other is to using a T connector piece, T into the feed coming again from the inlet manifold and then connect this to the DV but you then need to bung the connection that was previously attached to the DV. I used a bolt then clamped with a jubliee clip.
Hope this helps. :)
