Shock_Xe said:Not wanting to be negative but after this Long wait it seems that the car is gonna be off the road more than on, with problems that are cropping up
ibizacupra said:LMAO... well Adam is about to find out what real power and breakages is all about is'nt he!![]()
Transmission is THE WEAK LINK for those who have been asleep![]()
23psi boost on mine non its Hybrid and it kicks arse... (gear selection dependant-another issue)
BenS1 said:Hi Mike,
AFAIK the only problems with IHI'd Ibizas have been with either Bills car, which has far more boost than the normal stage 3, or with Ibizas running with standard diffs.... Jabba have clearly stated that the Ibiza gearboxs standard diff will not cope with the Stage 3 kit (Its on their website even now).
Not having a go at anyone here, but if you get the stage 3 upgrade on your car without fully preparing the car first (ie. upgrading the clutch and diff) then you can't blame Jabba when said parts fail (Not that anyone has blamed Jabba). This is not a reflection on the kits reliability.
AFAIK, no IHI'd car with uprated clutch and diff and running standard stage 3 bost has had any issues at all (Saying that, I don't think such a car is out there ATM!).
Ben
Jabba said stnd gearbox is good for 270lbs ft. And thats what they map it to dont they. I am sure a new clutch and uprated gearbox is req. Look how long jabbas demo car lasted on a stnd gearbox, quite a while
Madmile said:One of the limiting factors of the stage3 kit must be the IhI vf34 turbo. It will be flat out at 330-340bhp. It wont flow anymore air i am sure. The next jump would be summit like a IhI vf22 which would prob go to 400-420bhp ish (i may be wrong) but the lag may be quite severe on stnd compression with a boost spike of 18.5psi and 18psi sustained. The only good thing is jabba have had no turbo failures that we know of. So even though the turbo's at its max it seems to be coping. Most scoobs running ihi vf34's max out @ 320-340bhp roller dependent.
Not Stating any different!!!
Just saying that weaknesses in the car are showing, when mileage and age is added on...
Some one got the wrong end of the stick!
