Jesus, that didnt take long to arrive
All here just in time for the good weather to be working on it, have you sourced your crank yet
This is goin to be epic when its finished.. Wish i had the knowledge to do BT and get parts by myself
cant wait to see you finish it.. good luck mate
james.l;3****** said:Yer mate, might as well go the whole hog, going to get the head ported & polished / gas flowed as well!!
Haven't decided on the turbo to be honest, got 3 options
Tried and tested gt3071r, possibly with the larger hot side due to 2.0
Borg warner EFR6758 with 63 hot side, might even try the 7064 with 83 hot side. something untried currently in the uk
A hta gt frame turbo, 3076r with hta wheel
Still weighing up all my options really whilst I build the engine.
The efr is internally gated, and if I was going garret I would go external with tial waste gate in vband.
I don't mind a bigger turbo with the stroker & valve train as it will rev to 8.2k
What's your thoughts?
They all sound like gearbox killers to me! go for the HTA![]()
Just make sure you do you homework on availability of the EFR turbos if you go down that rout as it seams people have been waiting on them since 2010!!..
Will you be using a largeport head? . Are you planning on fitting cams?
What power are you after?
This is always a downside, I'll end up getting one from the USA as this is the only place with "stock"
I have just realised you have mentioned everthing I have asked previously in the thread
You will be making alot more than 400bhp with the turbo's you have lined up
Indeed it will be!
Yes I have engine code AGN are the best ones. N/A Audi A3's & Golfs were fitted with them.
