Can someone please answer me if I can program the ecu to auto rollup the windows with VAG-COM???
Thank you!
this is not possible with the ibiza and vag-com. Seat Tech (on here) says different but still waiting for answer :blink:
Yeh it is pretty handy to drop the windows on a hot day without having to get in the car. The kvw100 worked on my 2003, just need remote engine start to finish it off lol
exactlymy point when is it ever hot enough to need to do this :shrug: and even so use the key on the outside ;) just seems dear for £25 imo if it was programable on vag.com then it would have to be done as when you pullup in car parks you would pepously leave them down and looks pritty nifty!!
I also want this function and had the Autowindow module on my 2004 FR. I took the Autowindow out the 2004 FR and have tried to install it in my 2006 Facelift FR TDi. It appears that the wiring is not only a different colour, It all does different functions to the pre-facelift model! I've managed to install the Autowindow module but I can only use it to put the windows up, the down function doesnt work!
I would say the KVW100 Module only works in pre-facelift cars due to this. I emailed the guys that sell these modules and they say similar.
Cheers.
there must be a way to enable this option!!!!
Must be A WAY!!!!!
my msn convo with the company who makes these devices and i think its a no go :cry:
kvw100 says:
HELLO
Michael says:
http://car-diagnostic.com/index.php...product_id=95&option=com_virtuemart&Itemid=26
Michael says:
they say ur product does 2007 range ibiza
Michael says:
is this true
kvw100 says:
NO . HE IS MY DEALER. I AM CORRECT. THAT IS MY OLD DESCRIPTION
Michael says:
ah
Michael says:
ok
Michael says:
so no luck with developing one for the 2007 ones yet?
kvw100 says:
no possible
Why it's not possible to recode the ecu if the ecu remain the same as the 2003-2005 ware???? (6Q0 959 433 E/F)
The 2008 ibiza cupra has the same comfort module (6Q0 959 433 E/F)
I wonder
Assuming the car is fly by wire as such, and the window switchs do not connect directly to the window motor it must be possible to get this option to work.
LET ME KNOW IF YOU SORT THIS OUT. I too have had direct contact with the people that make these units, THEY DON'T WORK ON FACELIFTED IBIZA'S!!!
If you find a company that does a different unit and is tried and tested to work on facelifted ibiza's let me know about this also
thanks
