Lambda issues!
Parsy-Cupra
My car was driving really rough and doing bad mpg, so plugged in vag com and it said it was the lambda sensor. So just fit a new lambda sensor (from seat) and all was good again then drove bout 100 miles then this flashed up.
1 Fault Found:
16514 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit
P0130 - 35-10 - - Intermittent
The cars been driving fine, good mpg. Stuck on what to do, anyone got any ideas???
RUM4MO
8,111
1,125
South Scotland
I'd guess that your best bet will be to check the wiring round about the plug/socket as that code description seems to exclude the probe signal output or heater circuit. I take it that you had a different fault code before you changed the probe the previous time.
cuprakris
leon cupra
Dec 28, 2008
84
ipswich
hi i had the same problem and i had to clean the plugs out and spray terminal connecter stuff and clean the right out after that it worked perfect again
Parsy-Cupra
Yeah the code was different, i'll have a look at it then. Cheers guys!!
