I have an 04 LCR, took it for an MOT today and its failed on the emissions for the standard idle and fast idle, also failed on the lambda readings on the first test but not on the retest (I asked them to take the car for a run for 15 mins prior to the retest)
Car is running the standard map and has the blueflame turbo back system
Has anyone else had problems with MOT's with this exhaust fitted?
I have always had problems with the engine light coming on (efficiency below threshold IIRC) but had the system checked by blueflame and had the car up to awesome numerous times (once for a whole week) but the cars always said to be fine
I've read on here and been told that you can eliminate the engine light by spacing the lambda probe but would this also help with the emissions?
Lastly are there any checks I can do myself for emissions? I know I can check the lambda readings on vag-com but I think I'll need more than that to check it will pass the MOT
