Determined to get my downpipe off ready for the 3" downpipe and decat....in the pouring bloody rain
Downpipe off, not too difficult but made harder laying on the drive way
Spot the restriction. 3" DP vs the restrictive supposed updated downpipe from Blueflame which is measuring in at just over 2.2"
So I got the spark plugs changed, which had not been changed since the turbo went pop.....they were very oily
Old Vs New
This was the plug nearest the turbo
Next was to pull out the sensors from the existing exhaust, but first I had to get this bolt out of the decat which was a pig...ended up putting the spanner and standing on it, which released it
sensors out and then I put them in the 3" DP and decat....again standing on the spanner to undo the sensors!
Then my outside light went pop!
Inside of the old cat as well
Next will be getting the DP and decat on, and changing the fuel filter
Time to replace the rocker cover gasket and the valve cover gasket
Valve cover off, came off nice and easy too
Bit of dried gunk on the 4th valve <!-- s:? -->:?<!-- s:? -->
This is the old valve cover gasket, the 4th one which was where the oiliest spark plug was....I couldn't notice any splits or particularly worn gasket
Fresh nuts also
Now just the exhaust to go and tracking. angle grinding the fecking nut on Monday!
Stage one to losing some more weight out of the car, this turned up :)
Corbeau Pro Kevlar, weighing in at 8.6kg, compared a good 35kg+ for my leather electric seats. Only one at the moment as I couldn't afford two at the same time, so the second one will come later.
Other developments recently are my 3" Downpipe and decat are now on the car, and has made a big difference. You can really hear the turbo spooling even more now. Thanks to Nick.
Getting the seat fitted on the 10th March, then next up will be ordering my water meth kit
Box steel arrived ready for the bucket seat being mounted
Relocating the battery
Some very useful pics for me.... when I come to put mine back together! I'm so tempted to mod mine, but I bought it to save cash.... not spend more! Bah, this looks awesome.
Bucket seat was installed. Started at 9 and finished at 18:00.....for one Seat. I did not realise the amount of work that went into this, but wow.
Nick is an absolute legend, and his technical skills amazed me today.
Today started off like this, at Prawn HQ
Seat out
Nick drilling out the welded OEM Seat rails
Mess around the car
Nick cutting out the 3mm steel for the box steel to be welded too
Nick Tack welding the steel to the sides
This was then removed, and sprayed up (to ensure this doesn't ever rust)
All done
Welding bolt eye into place
Half done
Lovely jubbly
More Welding
Seat rails in
Trial Mounting Seat
AND fitted, sorry for the poor pic, but this was late, we were frozen beyond belief!
Ordered my water methanol kit, DVC30 progressive kit, with low level float warning and 4 quarts tank. This also comes with the sensor showing the pump is actually pumping to stop any issues with detonation etc which is pretty important!
Removed the spoiler and wing mirrors which are being wrapped in carbon
Removed the front bumper also as the headlights are getting tinted in laminex also.
Passenger side mirror off and glass taken out. This was a pain in the ass as one of the bolts had corroded so had to be drilled out.
Spoiler removed
Ready to be sent off
Finally removed the passenger door speaker, and removed the drivers door speaker also
Cleaned up the area where the spoiler was, as it was minging
Took the gauges out of the old Audi mounting brackets and trial fitted them
Perfect fit
Notice how the fittings are slanted also, so they point towards the driver :D
Got myself a Makita angle grinder as well, as I need to cut up some steel plates to hold the alloy battery cage in and start making my custom heat shield
Also sent off the spoiler, wing mirrors and headlights off to GStar wraps today to get wrapped http://www.gstarwraps.com/
plan today was to get some more airflow to the FMIC
Bumper
Half cut out
Done
I tidied it up a little bit after this as well
hanging on after drilling the crash bar a bit as well, as you can see its quite a bit more flow to the FMIC with the number plate cut out
Bits cut out
Cut out.....actually looks wonky the holes cut but that's because parts of the bumper are sunken
Took it off and drilled the back with a larger hole saw to maximise flow
Naked again
Tidied up the crash bar and finished off spraying it
Decided to clean up the points where the crash bar mounts to
Before
Sprayed
Dried and done
3m carbon arrived to finally do the missing bumper cover
In yellow, but that doesn't matter
Carbon covered
Parts have arrived for the gauges today
oil pressure sender
Sump plug and sump plug oil temperature sensor
and my bits are ready from GStar wraps....SUPER excited about these :D
Massive thanks to them. They can be found by searching for GStar wraps or www.gstarwraps.com
Few bits arrived for the car. Some of the cars performance issues is related to the stat and temp sensor as these are bringing the engine management light on, and this can really affect fueling etc.
This figures because the mpg I get is piss poor even when coasting off boost and is effecting power top end as I don't think it can work out fueling correctly. Either running lean or rich
Stat
Temp sensor
Boss to be welded into the metal intake pipe for my water methanol injection
More updates to follow this Friday when it gets put back together :)
Battery relocation is a work in progress at the moment
cut the brackets to pin the battery cage down. The lips on the end of the battery cage were to narrow and too thin to put bolts put through them, so I cut my 3mm steel left over
cut and drilled the ends
[/URL]
Started spraying them up, and the other black bracket is the top which goes over the top of the battery in the cage. The cage is too bling for my liking to its getting sprayed satin black also
Trial mounted in the boot. You can just see the ends of the battery cage where they are too thin, so the metal bars will be clamping this down.
I'm going to spray the white patch in the spare wheel well also at the weekend.
Then all I have to do is drill the foot well and bolt it down, fit the negative cable then that's job done and I can start on the supersize TIP.
