CupraUK
Pushing on
Aug 15, 2005
1,350
Bedfordshire
A cheap and cheerful way of venting your IC like an S3/TT (About £3)
You'll need:
Parts - B&Q 16 Louvre Aluminium Boiler Vent, Rivets, 4mm washers
Tools - Stanley knife, drill, pencil, rivet gun
Time - About 1 hour
1) Get yourself an large (they do a small and a large) 16 louvre aluminium boiler vent from B&Q, they are £3.08. The advantage over plastic is that you can bend them nicely into shape (keep bending it until it sits nicely in the curve of the arch)
2) It comes with only 4 holes which is not sufficient so drill two more at the top and bottom making 8
3) Jack your pride and joy up and put on axle stands or something that will keep you alive. Take the wheel off.
4) I did not remove the inner arch. Hold the vent up against the inner arch and bend into shape until it sits nicely all the way around.
5) Remove the wheel and mark up the wheel arch by drawing around the vent, mark where the louvres come to and then draw an inner rectangle when you take the vent off which is well inside the holes
5) Get a brand new stanley knife and cut out the inner rectangle. Be careful, you will need to put your hand behind to do this so don’t cut your fingers off.
6) Get some rivets and a river gun. Important: The plastic is quite soft so you MUST put 4mm washers on the back on the rivets to prevent them pulling through.
7) Rivet the vent on (Washers are on back of rivets on otherside)
9) Either leave as silver or paint black (I painted black)
Difficult to tell. I would say no more chance than the official Audi vent has.
Certainly when moving the wind from the wheel would be moving the air away, rather than torwards the openside of the vents.
I did this job 3 years ago this month and I've not had any problems.
Look good matey, i may well give this method a go seeing as it's only £3, and a bit of effort rather than £20 and a lot of effort...
this seems a good idea how ever i still believe crap more than water getting up there could be a problem.
So my idea is that a bit of fly mesh which is often used with loures could be put behind there to cut down the wheels flicking stuff up in to there
Funny you should say this, cos i was thinking the same thing, and thought the smic could get hit by flying debris, so went to halfords and a got some of that thin mesh you can use to do body repairs for £1.49.
So when i do mine, i'll stick that over the inlet, once it's been opened up a bit..
ull just really want to keep mud/stones/gunk etc out that could damage the core of the I/C
louvres facing down its unlikely you'll get stones through the slats but there is a chance-bit of meshing should solve it
There's nothing there normally, just because the hole's a bit bigger doesn't mean that it did not stand a chance before of getting a stone or something in there. I'm always clearing stones, leaves and other crap out of the entrance hole.
I've never heard of anyone having a problem.
Standard intercooler can be had for as little as a 10er anyway!
Quite possbily matey, doesn't mean i want to have to keep buying a replacemnt every few week/months tho.... :no:
That would be complete madness, when a simple piece of mesh over the hole will stop it.... :whistle:
Or even not opening it up so big, would probably solve it aswell Eh...;)
Well ive removed the air vent from under the bumper to intercooler and it has made some improvement.
Quicker cooling and a lower temp compared to my previous log
Quick log
Code:
Sunday	16	September	2007	13:34:17
06A 906 032 T  		1.8L R4/5VT         0003
	Group A:	'118
		Engine Speed	Air Temp In	Boost Dut Cyc	Actual Boost
	TIME	700-6800 RPM	<=110 C	0-100% 	<=1800 mbar
MARKER	STAMP	 /min	°C	%	 mbar
	0	720	42	0	1000
	0.4	720	43	0	1000
	0.9	1400	43	0	1000
	1.3	1600	42	0	1010
	1.74	1400	42	0	1020
	2.19	1480	41	100	1040
	2.59	1920	39	67.8	1110
	2.99	2440	39	38.8	1220
	3.39	2960	39	22	1360
	3.79	3360	38	0	1370
	4.19	3000	37	0	1130
	4.59	2560	37	0	1060
	4.99	2040	37	0	1030
	5.49	2200	39	0	1030
	5.89	2280	39	0	1070
	6.29	2400	38	0	1090
	6.8	2560	38	0	1110
	7.2	2680	38	0	1180
	7.6	2400	37	0	1120
	7.98	2000	37	0	1050
	8.38	1880	38	0	1030
	8.78	1880	39	0	1020
	9.18	1880	39	0	1010
	9.58	1880	39	0	1010
	10	1960	39	3.5	1010
	10.38	2040	39	2	1060
	10.78	2120	39	0	1120
	11.49	2200	39	0	1200
	11.98	2400	38	100	1350
	12.38	2560	38	100	1520
	12.78	2720	38	100	1680
	13.18	2920	38	100	1850
	13.58	3120	38	100	2050
	13.98	3360	39	99.2	2260
	14.49	3680	39	91.8	2350
	14.89	3920	39	88.2	2320
	15.29	4160	40	87.5	2280
	15.69	4360	42	87.8	2220
	16.09	4560	43	87.8	2160
	16.49	4720	45	89.4	2080
	16.95	4920	45	90.2	2030
	17.39	4600	45	0	1520
	17.79	4040	44	0	1140
	18.29	3840	44	5.9	1290
	18.7	3840	45	0	1340
	19.18	3800	43	0	1150
	19.58	3800	42	0	1050
	20	3800	43	0	1080
	20.48	3800	45	0	1350
	20.99	3800	44	0	1210
	21.48	3720	42	0	1070
	21.88	3680	42	0	1040
	22.28	3640	43	0	1040
	22.68	3560	43	0	1030
	23.08	3520	43	0	1030
	23.58	3520	43	0	1010
	23.98	3480	44	0	1010
	24.4	3480	44	0	1130
	24.88	3520	45	0	1370
	25.39	3600	45	100	1560
	25.79	3680	45	91	2060
	26.19	3840	47	98.4	2260
	26.93	3920	48	95.7	2280
	27.37	4160	50	90.6	2250
	27.77	4280	50	88.2	2220
	28.19	4400	51	87.5	2200
	28.57	4480	52	87.5	2160
	28.97	4560	54	87.8	2120
	29.39	4520	54	62	1910
	29.79	4560	51	0	1260
	30.28	4440	50	0	1080
	30.78	4240	49	0	1050
	31.18	4040	48	0	1040
	31.68	3840	48	0	1030
	32.26	3600	48	0	1030
	32.68	3440	48	0	1030
	33.08	3360	48	0	1020
	33.48	3320	48	0	1020
	33.88	3280	47	0	1020
	34.28	3240	47	0	1020
	34.68	3200	47	0	1010
	35.08	3160	47	0	1020
	35.48	3120	46	0	1020
	35.88	3120	46	0	990
	36.28	3120	47	71	1010
	36.68	3200	48	100	1380
	37.08	3280	49	100	1790
	37.47	3400	50	99.6	2160
	37.87	3480	51	0	2160
	38.27	3400	46	0	1200
	38.67	3360	45	0	1070
	39.07	3320	45	0	1040
	39.47	3320	45	0	1030
	39.87	3280	45	0	1020
	40.27	3280	45	0	1010
	40.67	3280	46	0	1060
	41.07	3320	47	0	1160
	41.47	3320	48	0	1360
	42.01	3320	46	0	1190
	42.47	3320	45	0	1060
	42.87	3280	45	0	1040
	43.27	3240	45	0	1030
	43.67	3200	45	0	1020
	44.17	3160	45	0	1010
	44.67	3120	46	0	1020
	45.07	3120	45	0	1040
	45.47	3120	45	0	1040
	45.98	3160	45	71.8	1030
	46.38	3240	47	100	1430
	46.76	3360	48	100	1860
	47.16	3480	49	88.6	2190
	47.59	3600	50	96.1	2320
	48.07	3760	50	92.2	2320
	48.47	3880	51	89.4	2300
	48.97	4040	52	89	2270
	49.47	4160	54	87.1	2240
	49.87	4280	54	87.1	2220
	50.27	4400	56	87.1	2200
	50.67	4520	57	87.5	2160
	51.07	4600	57	87.5	2130
	51.47	4680	59	88.2	2090
	51.87	4800	60	89	2080
	52.27	4880	61	89.8	2050
	52.67	4960	62	91.4	2030
	53.07	5040	63	93.3	2000
	53.47	5120	64	94.9	1990
	53.96	5200	66	95.7	1970
	54.38	5280	66	96.5	1950
	54.78	5360	67	96.9	1940
	55.27	5360	68	0	1810
	55.67	5320	64	0	1210
	56.07	5160	62	0	1080
	56.46	4960	60	0	1050
	56.86	4760	59	0	1040
	57.47	4520	58	0	1040
	57.96	4200	57	0	1030
	58.36	4000	57	0	1030
	58.76	3840	56	0	1030
	59.16	3640	55	0	1030
	59.56	3400	55	0	1030
	59.96	3200	54	0	1020
	60.36	3040	54	0	1020
	60.76	2920	54	0	1020
	61.16	2760	54	0	1020
	61.56	2640	54	0	1010
	61.96	2600	54	0	1010
	62.36	2560	54	0	1010
	62.76	2520	53	0	1010
	63.26	2480	53	0	1010
	63.66	2480	53	0	1010
	64.06	2480	53	0	1020
	64.57	2480	53	0	1030
	64.97	2480	52	0	1020
	65.37	2480	52	0	1020
	65.77	2400	52	0	1010
	66.15	2400	52	0	1010
	66.55	2360	52	0	1010
	66.95	2360	51	0	1010
	67.35	2360	51	0	1000
	67.75	2280	51	0	1010
	68.15	2280	51	0	1010
	68.55	2200	51	0	1010
	68.95	2080	51	0	1010
	69.46	1960	51	0	1010
	69.86	1880	51	0	1010
	70.36	1720	51	0	1010
	70.76	1440	51	0	1010
	71.26	1160	51	0	1000
	71.66	1000	51	0	1000
	72.06	840	51	0	1000
	72.58	720	51	0	1000
	73.06	720	51	0	1000
	73.56	720	51	0	1000
	74.04	720	51	0	1000
	74.44	760	51	0	1000
	74.84	760	51	0	1000
	75.24	720	51	0	1000
	75.65	760	51	0	1000
	76.05	720	50	0	1000
	76.55	720	50	0	1000
	76.95	760	50	0	1000
	77.35	1080	51	0	1000
	77.75	1320	51	0	1000
	78.2	1560	51	0	1010
	78.65	1840	51	0	1010
	79.05	2160	51	0	1040
	79.45	2520	51	0	1060
	79.85	2880	51	0	1100
	80.25	3280	51	0	1280
	80.65	3080	51	0	1220
	81.05	2600	50	0	1080
	81.45	2200	50	0	1040
	81.85	2280	50	0	1010
	82.25	2360	51	0	1040
	82.65	2480	51	0	1090
	83.16	2640	51	0	1100
	83.56	2760	51	0	1100
	83.96	2840	51	0	1100
	84.36	2920	51	0	1090
	84.76	3000	51	0	1090
	85.25	3080	51	0	1100
	85.65	3200	51	0	1230
	86.05	3280	52	0	1320
	86.45	3440	52	0	1300
	86.95	3720	53	100	1470
	87.35	4120	54	92.2	2030
	87.94	4600	56	98.8	2160
	88.45	5200	57	100	1970
	88.85	5520	58	100	1890
	89.37	5920	60	95.7	1790
	89.77	6240	61	92.9	1730
	90.17	5920	62	0	1810
	90.55	5200	59	100	1100
	90.95	4680	59	100	1560
	91.35	4800	62	94.1	2020
	91.75	5000	63	100	2010
	92.15	5160	63	98.4	1970
	92.55	5360	64	100	1930
	92.95	5280	66	0	2020
	93.35	4640	63	0	1200
	93.84	4320	63	100	1650
	94.34	4440	64	95.7	2150
	94.74	4560	66	100	2150
	95.14	4640	67	100	2130
	95.54	4760	68	100	2100
	95.94	4840	69	100	2080
	96.36	4960	69	100	2050
	96.76	5000	69	100	2030
	97.16	5120	71	100	2000
	97.65	5120	72	0	1890
	98.05	5120	68	0	1250
	98.44	5040	66	0	1100
	98.85	4880	63	0	1060
	99.24	4680	63	0	1040
	99.64	4520	62	0	1040
	100.04	4320	61	0	1040
	100.44	4160	61	0	1040
	100.95	3920	60	0	1030
	101.44	3760	59	0	1030
	101.84	3640	59	0	1030
	102.34	3400	58	0	1020
	102.74	3280	58	0	1020
	103.24	3200	57	0	1020
	103.75	3040	57	0	1020
	104.15	2960	57	0	1020
	104.55	2920	57	0	1020
	104.93	2880	57	0	1020
	105.33	2880	57	0	1010
	105.73	2880	57	0	1010
	106.13	2880	57	0	1020
	106.53	2920	57	0	1050
	106.93	2920	57	0	1060
	107.33	2920	57	0	1060
	107.73	2960	57	7.1	1040
	108.13	3000	57	8.2	1350
	108.53	3080	58	0	1360
	109.06	3120	57	0	1320
	109.54	3160	57	0	1170
	109.94	3200	57	0	1140
	110.34	3240	57	0	1290
	110.74	3320	57	0	1360
	111.14	3400	58	100	1390
	111.54	3520	59	100	1840
	111.94	3640	61	91.4	2190
	112.34	3760	62	98.4	2290
	112.83	3920	63	96.5	2290
	113.23	4040	63	94.1	2290
	113.73	4200	64	92.5	2260
	114.24	4360	66	89.8	2250
	114.74	4480	66	80	2220
	115.14	4520	67	66.3	2020
	115.54	4520	66	0	1390
	115.94	4440	63	0	1120
	116.43	4240	61	0	1060
	116.83	4080	60	0	1040
	117.23	3840	59	0	1040
	117.63	3680	59	0	1030
	118.13	3480	58	0	1030
	118.81	3280	58	0	1020
	119.23	3000	57	0	1020
	119.63	2920	57	0	1020
	120.03	2800	57	0	1020
	120.53	2680	57	0	1020
	120.93	2640	57	0	1020
	121.33	2560	57	0	1010
	121.73	2560	57	0	1010
	122.22	2560	57	0	1020
	122.74	2600	57	0	1000
	123.14	2640	57	100	1070
	123.54	2720	58	100	1320
	123.92	2840	59	100	1580
	124.35	2960	60	100	1820
	124.83	3120	61	100	2070
	125.23	3240	62	93.3	2250
	125.73	3200	61	0	1770
	126.13	3320	57	0	1160
	126.53	3240	55	0	1070
	126.93	3080	55	0	1040
	127.33	2880	55	0	1030
	127.73	2680	55	0	1020
	128.22	2440	55	0	1020
	128.62	2360	55	0	1020
	129.02	2240	55	0	1020
	129.42	2200	55	0	1020
	129.82	2120	55	0	1020
	130.22	2040	55	0	1020
	130.62	2000	55	0	1020
	131.02	1960	55	0	1010
	131.42	1960	55	0	1010
	131.92	1920	55	0	1010
	132.43	1840	55	0	1010
	132.93	1800	55	0	1010
	133.42	1760	55	0	1010
	134.03	1760	55	0	1010
	134.53	1680	54	0	1010
	134.93	1680	54	0	1010
	135.33	1680	54	0	1000
	135.73	1680	55	0	1000
	136.22	1680	55	0	1020
	136.62	1680	54	0	1020
	137.02	1720	54	0	1020
	137.42	1680	54	0	1010
	137.82	1640	54	0	1010
	138.32	1640	54	0	1010
	138.7	1600	54	0	1010
	139.12	1600	54	0	1010
	139.53	1560	54	0	1010
	140.01	1560	54	0	1010
	140.41	1520	54	0	1010
	140.81	1520	54	0	1010
	141.21	1480	54	0	1010
	141.61	1480	54	0	1010
	142.13	1440	54	0	1010
	142.53	1280	54	0	1010
	142.93	1040	54	0	1000
	143.41	840	54	0	1000
	143.82	1240	54	0	1000
	144.32	1680	54	0	1000
	144.72	1680	54	0	1000
	145.12	1680	54	0	1000
	145.52	1600	54	0	1000
	145.92	1600	54	0	1000
	146.41	1560	54	0	1010
	146.81	1520	54	0	1010
	147.21	1480	54	0	1010
	147.71	1400	54	0	1010
	148.11	1440	54	0	1000
	148.51	1480	54	0	1000
	149.25	1440	54	0	1000
	149.71	1520	54	0	1020
	150.22	1560	54	0	1060
	150.62	1520	53	0	1040
	151.02	1520	52	0	1020
	151.42	1480	52	0	1010
	151.82	1400	52	0	1010
	152.22	1240	52	0	1010
	152.62	1000	53	0	1000
	153.01	840	53	0	1000
	153.41	720	53	0	1000
	153.81	720	53	0	1000
	154.21	720	53	0	1000
	154.61	720	53	0	1000
	155.1	720	53	0	1000
	155.5	760	53	100	990
	155.92	1440	53	0	1010
	156.41	1280	53	0	1020
	156.81	1520	53	41.2	1030
	157.21	1880	54	17.6	1110
	157.61	2320	54	18.4	1190
	158.01	2760	54	0	1280
	158.41	3160	54	0	1300
	158.81	3000	53	0	1240
	159.21	2520	51	0	1090
	159.61	2000	51	0	1020
	160.11	2200	53	0	1050
	160.51	2360	53	3.1	1090
	160.91	2560	54	30.6	1250
	161.4	2880	54	100	1440
	161.92	3280	55	100	1820
	162.32	3760	56	90.2	2150
	162.72	4200	57	98.8	2250
	163.1	4640	58	99.2	2160
	163.52	5000	59	100	2040
	163.92	5320	60	100	1940
	164.44	4680	58	0	1260
	164.91	3760	57	100	1330
	165.31	3960	59	100	1940
	165.8	4200	61	98.8	2240
	166.2	4400	62	97.3	2230
	166.6	4560	63	96.9	2180
	167	4800	64	97.3	2130
	167.4	4840	66	98.8	2080
	167.82	4360	63	0	1390
	168.3	3680	60	0	1100
	168.7	3160	59	0	1050
	169.1	2640	58	0	1040
	169.61	3240	57	0	1020
	170.08	4040	57	0	1030
	170.51	4080	57	61.6	1070
	171	4200	60	100	1780
	171.5	4440	63	98	2170
	172.01	4680	64	100	2130
	172.51	4840	66	100	2070
	173.02	5080	67	100	2020
	173.42	5200	68	100	1970
	173.9	5400	69	100	1930
	174.31	5480	71	96.5	1890
	174.71	5000	68	0	1290
	175.19	4240	66	0	1090
	175.59	4160	64	0	1060
	175.99	4240	64	100	1260
	176.39	4320	67	94.1	1940
	176.79	4400	68	99.6	2190
	177.31	4520	69	98	2180
	177.71	4600	71	96.9	2170
	178.2	4640	69	0	1650
	178.7	4520	66	0	1130
	179.1	4400	64	0	1070
	179.5	4280	63	0	1050
	180.06	4160	63	0	1040
	180.51	4080	62	0	1040
	180.91	4000	62	0	1030
	181.31	4040	62	76.1	980
	181.71	4080	63	100	1470
	182.11	4200	66	89.8	2060
	182.51	4280	67	99.6	2220
	182.89	4400	68	98.4	2220
	183.29	4480	69	97.3	2190
	183.69	4600	69	96.9	2160
	184.09	4680	69	96.9	2140
	184.51	4760	71	97.6	2110
	184.89	4880	72	98.4	2090
	185.33	4960	74	100	2070
	185.8	5040	74	100	2040
	186.3	5160	75	100	2010
	186.71	5240	76	100	2000
	187.11	5320	76	70.2	1970
	187.5	5320	75	0	1380
Asume so, the power stays longer after a few runs. as the temp coolers down quicker due to more air hitting ic.
