20v roper
272
hello, im new to this so be gentle with me!! can i swap the 3 grille pieces on my leon on which the slats run horizontally for the honeycomb items seen on other leons?? and is it expensive to do? many thanks.....
If you have a LCR or an FR+ then this mod doesn't work, as the centre S is a different shape. All other models are fine though :)
I was going to fit a badgeless grille to my 20VT prefacelift, untill i realised it was a one piece unit and needed to be cut about, and couldn't be bothered with all that... but thats just me.. :redface:
The badgeless part isn't, it's just the two side grilles that are one piece (and require bumper removal)
The grille with the S just pops out
Will the outer grills fit a LCR or FR+ ?
Yes. Infact, if you're handy with a dremel (and can be arsed) you can almost make a honeycomb S badge to fit the LCR out of a spare side grille. Have a look around for honeycomb LCR grille...it's been done
