Hiya,
The last days it has been raining quite a bit here in the Netherlands. All of a sudden I get this message (during driving) that the tailgate is open. But the message doesn't stay on screen, it shows and dissappears every few seconds. At the same time the interior lights switch on and off...After a while, the message will stay on screen, showing a red tailgate.
I found out that when behaviour occurs, the rear light cluster (only the ones on the tailgate) start blinking. I also found out that in this situation the reverse light is not working. Mind you, the boot latch is working as it should. I can open & shut the bootlid without any issue. No faults on the Autel or Torque Pro.
Also, it's intermittent. Yesterday I took if for a half hour drive, nothing happended. It was dry though...
-Display shows red "open" tailgate
-Interior lights switch on/off together with the error message appearing/dissappearing
-Boot latch works normally
-Rear light cluster (only the ones on the tailgate) blink if the error message appears/dissappears
-Reverse light does not work with error message
-Intermittent, seems related to (a lot of) rain
-Autel Maxipro shows no errors
I suspect something with earth wire or water ingress somewhere
Does this sound familiair to someone with an ST?
