OK from my understanding your basically get pipe vibration when your lightly on the pedal. I get that when I am lightly on the throttle every now and again. It happens for like half a second to a second. Its almost like there isnt enough boost going through the pipework because too little throttle is being pressed? I think thats normal unless it isnt? Car never had any sort of power issues at all or hesitation unless its been really really hot.
Sounds to me like EGR, like muddy said at the start of the thread. I had a similar thing with my 110 when i got it. You have a 150 from memory which has the seperate N75 and N18 valves on the back firewall, swap them over and see how it goes....
Yeh, I was supposed to do that this weekend, but I had lazyitus.
Took the car out on Saturday, and I must say its running bloody lovely on full throttle, feels really quick at the mo, and since doing the ECU reset my MPG recovers much quicker after a good boot.
Shall swap the N18 and N75 over, just wish I had the nack of getting my EGR off too, I might just book it into garage for it doing - I need a bigger variety of tools!!
I had this on my Leon, had a look and one of the boost hoses was half out, had a golf TDI 150 and the same thing happened, but quite jerky.
Reet, I have limp mode at last............:)
Car has been jerking quite bad last couple of days, and when I start it up a nice carbon spray comes out of my exhaust and stains the paving blocks.
Took laptop out tonight for logging. As i'm flooring it in 3rd I get a huge hesitation and limp mode.
17965 - Charge Pressure Control: Positive Deviation
P1557 - 35-00 - -
Limped it to a lay-by and restarted, car goes like the clappers again and the smoke when booting it has died right down back to normal again.
Got a log to post too, if I can get my file sharing to work again. lol
Code:
	Group A:	003
		Engine speed	MAF (specified)	MAF (actual)	EGR duty cycle
	TIME	790-870	230-350	210-370	40-75%
MARKER	STAMP	 /min	 mg/R	 mg/R	 %
	0.94	1533	460	220.5	60.2
	1.76	1554	850	823.2	4.8
	2.58	1743	850	1234.8	4.8
	3.38	1995	850	1249.5	4.8
	4.17	2268	850	1249.5	4.8
	4.97	2520	850	1249.5	4.8
	5.77	2730	850	1249.5	4.8
	6.58	2940	850	1249.5	4.8
	7.38	3108	850	1195.6	4.8
	8.17	3255	850	1127	4.8
	8.97	3402	850	1048.6	4.8
	9.77	3528	850	1019.2	4.8
	10.57	3633	850	965.3	4.8
	11.39	3738	850	965.3	4.8
	12.21	3801	850	906.5	4.8
	13.04	3843	850	926.1	4.8
	13.85	3927	850	901.6	4.8
	14.65	3948	850	935.9	4.8
	15.44	3969	850	945.7	4.8
	16.24	4032	850	906.5	4.8
	17.04	4074	850	891.8	4.8
	17.84	4116	850	886.9	4.8
	18.67	4095	850	886.9	4.8
	19.49	3969	850	837.9	4.8
	20.32	3780	850	406.7	4.8
	21.13	3612	820	352.8	4.8
	21.92	3465	445	352.8	4.8
	22.72	3339	340	367.5	4.8
	23.52	3192	325	372.4	4.8
	24.32	3066	315	377.3	4.8
	25.13	2919	305	387.1	4.8
	25.93	2793	295	396.9	4.8
	26.73	2667	280	406.7	4.8
	27.53	2541	270	401.8	4.8
	28.35	2415	260	401.8	4.8
	29.18	2289	250	401.8	4.8
	29.99	2163	240	401.8	4.8
	30.79	2058	230	401.8	4.8
	31.6	1932	230	401.8	4.8
	32.4	1827	230	406.7	4.8
	33.19	1722	230	401.8	4.8
	33.99	1596	235	411.6	4.8
	34.79	1491	245	401.8	4.8
	35.59	1092	250	445.9	4.8
	36.39	819	250	328.3	68.5
	37.19	1722	230	318.5	69.7
	37.99	1743	230	289.1	78.9
	38.79	1638	340	298.9	80.5
	39.59	1596	365	303.8	62.2
	40.39	1596	390	347.9	55.4
	41.19	1617	390	382.2	54.2
	41.99	1617	385	396.9	55.4
	42.79	1638	380	387.1	56.6
	43.59	1659	445	392	52.6
	44.39	1743	540	445.9	31.5
	45.19	1890	830	470.4	4.8
	45.99	2037	850	475.3	4.8
	46.78	2163	850	480.2	4.8
	47.58	2310	850	475.3	4.8
	48.38	2436	850	490	4.8
	49.19	2562	850	499.8	4.8
	49.99	2688	850	504.7	4.8
	50.79	2814	850	509.6	4.8
	51.59	2730	295	426.3	4.8
	52.39	1764	725	455.7	4.8
	53.17	1806	770	465.5	4.8
	53.97	1848	685	485.1	19.9
	54.78	1869	545	465.5	19.9
	55.59	1890	420	470.4	26.3
Code:
Group B:	011
	Engine speed	Spec. intake press.	Actual intake press.	D.cycle MAP
TIME	2850-3150	2300-2600	2200-2800	35-80%
STAMP	 /min			 %
0.53	1512	1044	1128	31.1
1.34	1512	1872	1152	29.1
2.18	1638	2256	1752	39.4
2.97	1848	2496	2592	59.8
3.77	2121	2628	2988	68.5
4.57	2394	2676	2988	73.3
5.37	2646	2688	2988	78.1
6.17	2856	2688	2988	83.7
6.97	3024	2688	2988	88.5
7.77	3192	2688	2988	92.8
8.57	3318	2688	2988	94.4
9.37	3444	2688	2988	94.4
10.16	3570	2688	2988	94.4
10.97	3654	2688	2988	94.4
11.81	3759	2688	2988	94
12.62	3801	2688	2988	94.4
13.44	3885	2676	2988	94.4
14.25	3927	2664	2988	94.4
15.05	3990	2652	2988	94.4
15.84	4032	2640	2988	94.4
16.64	4032	2640	2988	94
17.44	4095	2616	2988	94
18.24	4095	2616	2988	93.6
19.08	4011	2652	2988	92.4
19.9	3864	1092	2076	92.4
20.72	3696	1080	1116	92.4
21.52	3549	1068	972	92.4
22.32	3402	1068	960	92.4
23.12	3255	1056	960	92.4
23.92	3129	1044	960	92.4
24.73	2982	1044	948	92.4
25.53	2856	1032	948	92.4
26.33	2730	1020	960	92.4
27.13	2604	1020	960	92.4
27.95	2478	1008	960	92.4
28.76	2352	1008	960	92.4
29.58	2226	1008	972	92.4
30.39	2100	996	972	92.4
31.19	1995	996	984	92.4
31.99	1890	996	984	92.4
32.79	1764	996	984	92.4
33.59	1659	996	984	92.4
34.39	1554	996	972	92.4
35.19	1428	996	984	92.4
35.99	798	1044	996	92.4
36.79	1176	1068	972	92.4
37.59	1785	1104	972	92.4
38.39	1680	1152	984	92.4
39.19	1596	1308	984	92.4
39.99	1596	1356	984	92.4
40.79	1596	1368	996	92.4
41.59	1617	1368	996	92.4
42.39	1638	1356	996	92.4
43.19	1638	1392	996	92.4
43.99	1701	1536	1008	92.4
44.79	1806	1692	1044	92.4
45.59	1953	2568	1080	92.4
46.38	2100	2616	1104	92.4
47.18	2247	2664	1104	92.4
47.98	2373	2676	1104	92.4
48.78	2499	2688	1116	92.4
49.59	2625	2688	1128	92.4
50.39	2751	2688	1128	92.4
51.19	2898	1044	1128	92.4
51.99	1659	1644	1044	92.4
52.79	1785	2040	1080	92.4
53.57	1827	1980	1092	92.4
54.38	1869	1692	1104	92.4
55.17	1890	1620	1092	92.4
As you might expect from the "positive deviation" fault, your boost looks way too high - 2988mbar means you're nearly at 2 bar boost (once you subtract atmospheric pressure).
And then it stays there....
Sticking VNT mechanism is likely...
Can't remember what car you've got - do you have a separate N75 ?
Yeh I have the seperate N75. Are they easy to swap over? I've read lots about people braking the N75 as they try to pull the lines off.
Can't believe component failing at your mileage Chris :confused:
Your logs are a bit beyond me but would suggest one or 'tother mentioned.
I know, I don't have much luck with cars me.
I wrote off my 1st MKII Golf, my 2nd MKII golf had major carb problems, my 3rd car a pug of two years old had a disagreement with the gearbox, my 4th car a focus had a piston ring that was stuck closed.
Now my Leon is boosting all over the place.
:censored:
Just rung SEAT - He says I need a ECU flash.
Asked him if that would delete my remap and he said it would, I take it that is just like a IT guy saying reboot whenever a PC has a problem.
Warranty has run out too, and the guy that has helped me out over there has left SEAT, so its down to me to try fix this as cheaply as possible.
Humbugs!
Tried the EGR/VNT exercise routines from within VCDS? Maybe give them a 10-15 minute run each and see if the constant activation/deactivation frees up anything that's sticking a bit?
Can you go into any more detail with this?
VCDS? Can I only see the VNT exercise from underneath?
N75 is very easy to change Chris. Just 3 hole clips and an electrical plug.
I realy cant see a ECU flash doing anything mate. Its just the dealers way of trying to con more money out of you. Once they have re-flashed the ECU and the problem is still there they wont give you your money back will they!!
If it is something to do with the map I would speak to Will at P-torque. I'm sure he can give you some advice.
I had a very similar problem not long ago. I changed oil & filter (I know this wonte of done anything to help the problem), new DV, new plugs and a new coil pack.
I had a coil pack pop the same night I fitted the new dv (2 days before Awsome). Since then I have not had the problem come back.
Here is the thread with my problem clicky.
Just been for a quick snoop under the bonnet in the dark.
Should I have a vacume from the black hose that goes to top of EGR on tickover?
Cos I don't have any vacume, and I can't remember if i ever did?
Chris, when you installed your SFS piping kit did you keep the vacuum chamber?
I thought you had that hose clamped anyway to disable your EGR?
I unclamped the EGR about 2 months ago, never clamped it back up again.
Yeh Maz, my vacuum chamber is located where yours is - I checked this last night too to see if it was holding vacuum and it is.
I'm going out now to try take my EGR off again. Hopefuly will get it all off this time and shall clean in.
Then I'm planning on getting car up on ramps, and doing the N75 exercise, see if that shows me anything.
Then I'm planning on swapping over N18/N75.
Im struggling to get 40MPG now, before I could really tickle the car round and I could push 43-44MPG.
Thing that I dont understand is if I boot my car everywhere (like its stolen style then I get low 30 MPG, if I tickle the car everywhere I get 38MPG, and I just can't believe there is only 8MPG of difference between the 2 driving styles. :help:
Finally managed to get the EGR off completely, took me a good 3hrs.
Inside is completely cacked up with crap, not sure if the actual EGR mechanism is supposed to be so hard to move? I can't see any vacume moving my EGR, I couldnt get it to move by sucking it, unlike the ASV which moves easily by sucking on it.
Anyhow, i've fecked the rubber seal on the EGR when removing it, so need a new one of them and lost 2 bolts that never dropped through to the undertray.
Looks like a rescue job for me Monday, i'm never going to attempt taking the EGR off ever again, i'd rather pay someone £100 to do it.
