Found out the experiment here:
12V BoostPack Starts Freezing Cold Engine – Capacitors Replacing Car Batteries
A hybrid battery made from 6 x 350F supercapacitors and a Li-po battery from a RC car could give a start even in freezing cold, while being no more than 1 kg in weight.
Tried to make myself a similar pack, but with stronger supercapacitors and a sizable lead-acid battery to have more reserve.
Used 6 x 700F Nippon DLCAP capacitors in series, for a maximum of 15 volts, and a 10 Ah AGM battery for current reserve, all fitted together in a wooden box I did myself.
Goal: to get similar performance to a 60Ah lead-acid battery, in a package about 5 kgs in weight. This equals removal of 10 kgs from the extreme front end of the car, which helps to limit understeer.
Each supercap got a balacing circuit from CSDWell fitted in parallel to limit voltage.
Total weight fully assembled 5.7 kg, out of which 3.38 kg AGM battery, 1 kg wooden box + cables.
The system fits invisibly inside of the
Leon Mk1 battery box.
Results: starts much quicker at 0°C compared to lead-acid battery, voltage with engine running is stable at 14.4 volts engine warm, 14.6 volts engine cold, idle a bit smoother. Rpms climb a little bit faster, as the alternator hardly does any effort after the first few seconds needed to recharge the capacitors.
