hi ive got a 2006 fr pd170 just had a new valeo single mass flywheel clutch kit fitted and a dpf delete egr delete and stage 2 remap and have a problem when accelerating hard in 2nd build up some speed to about 20mph and at 2000 revs some times in 3rd but not as much i get a boost cut/traction control still on sort of cut out. It is fine in higher gears which is when normally boost cut out happens as its at higher boost in higher gears. note-the first time it happend was after fitted new clutch and flyhweel the day before the remap but ever since the remap bein faster accelerating does it every time i punch it in low gears its like the initial sharpness of the torque cuts somet out?? i had a look around sin somethin about a fuel pump possibly failing? any ideas really dyin to sort this appreciate any help thanks
