low gear boost cut on acceleration fr 170
Danwheeler2k11
mellow yellow
Jun 3, 2011
130
hi ive got a 2006 fr pd170 just had a new valeo single mass flywheel clutch kit fitted and a dpf delete egr delete and stage 2 remap and have a problem when accelerating hard in 2nd build up some speed to about 20mph and at 2000 revs some times in 3rd but not as much i get a boost cut/traction control still on sort of cut out. It is fine in higher gears which is when normally boost cut out happens as its at higher boost in higher gears. note-the first time it happend was after fitted new clutch and flyhweel the day before the remap but ever since the remap bein faster accelerating does it every time i punch it in low gears its like the initial sharpness of the torque cuts somet out?? i had a look around sin somethin about a fuel pump possibly failing? any ideas really dyin to sort this appreciate any help thanks
Danwheeler2k11
mellow yellow
Jun 3, 2011
130
Reply
It hapend once jus mildy the day before the map though, the map made it worse as accelerations been increased
kilner
324
the map i did a leon on here a few days ago and fixed his stuttering
not cheap tho :D
Danwheeler2k11
mellow yellow
Jun 3, 2011
130
Reply
What was the stuttering like tho pal same as mine 2nd 3rdgear when u i initialy accelerate hard
kilner
324
hold rpm at 2500 and then 100% throttle and it will cut like a very hard traction control even tho its not that
AndrewJB
Friend to SEAT UK & Cupra Racing
Aug 16, 2007
11,175
485
Maranello
its deffo the map its been well covered on here before.
99% of tuning companies don't know how to tune the Siemens PPD ecu correctly on these in the first place, 99% of companies also don't know how to fix the stuttering issues.
Danwheeler2k11
mellow yellow
Jun 3, 2011
130
Reply
Hold 2500 rpm in 1st then punch it? I dont normaly pull of hard in 1st due to wheelspins anoyin, but if i leave it til 2nd then pic u bout 20mph rpm at 2k then punch it its really bad an a lil in 3rd briefly but mildly, the place has done leons before even the guy who does it has the same and same map and his is fine?? Is there any diagnostics they can do see if anythings else is wrong? And who can actually map it wothout this happening?
holmefield
Forever messing with cars
Oct 20, 2013
578
Its the map as mentioned above...mines been back to my tuner to have it sorted once already and its going back again this week to have a new modifed again map as it wasnt sorted last time...
Danwheeler2k11
mellow yellow
Jun 3, 2011
130
Reply
So back 2nd time since u had it 1st remapped? Whats was your stutter like pal? Confuses me the guy has a leon himself and has done other leons without probs :shrug:
kilner
324
all mappers do to fix the problem is make the boost very progressive and back it off
i 100% fix the issue
go to a professional and ask for more than 27psi of boost they wont be able to do it
half of the tuners just up the boost and the fuel and when it dont work they cheat on fixing it
why do some cars smoke like hell to make 210 bhp and others dont ? boost was lowerd to stop stutter and from having low boost the car starts to smoke more
and also other things that are not touched
ill give it 4 months before my map fixes are in circulation and then all the so called professionals have found a miracle fix and offering software updates
yet i have had this cracked for over 12 months
and by teh way i did not say in first gear i said any gear try it in 3rd gear at 2500 rpm hald it at 2500 rpm up a steep hill and then mash the pedal to 100% this will replicate the issue 60% of the time
Danwheeler2k11
mellow yellow
Jun 3, 2011
130
Reply
Ye what would you says best for mine if my mapper cant fix it ? How much you charge for the map?
Danwheeler2k11
mellow yellow
Jun 3, 2011
130
Hi mate just wondering what you meant when u said mappers do to fix it is make the boost more progressive? Is that slower boost i take take it?
kilner
324
they bring the boost in very slow and dont hit max boost untill late on
you will loose some torq and midrange but still have a similar max power
Danwheeler2k11
mellow yellow
Jun 3, 2011
130
Ok cheers ill see what happens saturday when he has it back an go from there. If it isnt the map for instance is there anything else it could possibly be that cause similar issues?
kilner
324
make sure the n75 atmospheric line is not blocked its the one that conectes to the airbox and goes back to the n75 valve any restriction or blockage on that line and it will cause massive boost spikes
