m0rk's 1990 Eunos Roadster
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
Ahh
Well the fronts are on one side, and mostly removed from the other.
But I have the bottom shock bolt stuck, and with no way of getting it out normally - so I will be applying heat tomorrow.
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
Nearside ARB link & Lower wishbone currently on order after I cut the shock off with an angle grinder, and went through a few bits at the same time.
The lower damper bolt has corroded onto the lower shock bush, no amount of plus gas or heat was shifting it sadly.
Should be on the ground (literally) next weekend all things being well.
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
It really is an hour here, an hour there. Then ordering bits that arrive next day, but I have to wait until I'm back home to fit.
PITA really.
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
Woot
Enough parts arrived that meant I could wield my angle grinder & remove the old lower wishbone that I had damaged while trying to cut off the old suspension.
Anyway, new wishbone on, mostly new bolts all round & the 'new' damper fitted.
Dropped off the axle stands & just about got my low entry jack out from underneath. Proceeded to drive out of the garage & ripped off the bumper mounted fog light, turned it round & parked it out front of the house, ground out the chassis rails on the smallest of humps :lol:
Looks cool as hell, as I fitted my offset, small front number plate & new small rear plate also.
Now it's too warm to sit in the sun & finish off the wiring work I need to complete inside, but it's getting there!
Pics later on when it's less bright
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
Plate needs straightening
See mangled fog lamp
Rear Camber!
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
I think the rears have settled a lot more over the past couple of weeks.
It's going to be sat for a week or two now, so I'll probably raise them up, silly low is funny, but needs 8" rims to pull it off
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
there's a silver one local here that's slammed down over the rims god knows how he get's over the local humps ???
Mat Lock
Carless Wonder
May 24, 2007
626
Purley, Surrey
www.mat-lock.net
I just had a drive in a 1993 Eunos Roadster and it was the most fun I have had in a car in a long time. So quick, engine noise was awesome and stuck to the road like glue, albeit I only had a 5 minute ride around Purley which isn't at all easy to let rip around.
Great great fun though. Just tying to find a quote for insurance on it. I might be tempted to buy it hahah.
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
In Black
quite a lot cheaper than list price :) They had it as a BIN price as the normal starting bid
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
Cage arrived yesterday, so I'll set about getting that fitted later on.
It has BIG plates for the rear arch mounts, so I will talk to Stu about getting the welder out on those, I'm sure they'll be fine with just being bolted, but this won't hurt
Interior is mostly back together now too, so all my new wiring is tidier too now.
