Metallic rattle when reversing after a long drive
andyj
There's no F in Quality..
Got home for work last night (30min drive), and when I went to reverse on to/up my drive, I noticed a loud metallic rattle/jingling.....
Rolled forward again, no noise....
Reverse, rattling....
Had a look underneath but can't see anything hanging down etc.
When I got in the car this morning (i.e. cold car) I tried reversing, with no noise.
Will have a listen when I get in the car this evening after work when the car is cold, and see if there is a noise, and then again when I get home when the car is hot.....
My suspicion is that it is a heatsheild on the exhaust that is getting hot, and then vibrating.... but I can't understand when it's only when I reverse :confused:
NorthernMonkey2
Andy,
Its only a thought but on a transverse engine when you put it in reverse does it "tilt" the opposite way to forwards or move significantly? Would only take a nudge to push it against a shield.
I suggest it as my wifes Picasso engine moves quite considerably, not sure about the Alty.
Otherwise poss loose exhaust baffle or duff engine mount :confused:
Good excuse to spend a Saturday morning having a tinker.
If you find it let us know, always useful.
NorthernMonkey2
Good stuff
I've got a dashboard rattle - wonder if it'll also go now I've said it on here........
SeatCupraNet heals all!
:funk:
robint
168
9
UK, Essex
Chippings......
Have they been re-coating the roads near you - seems as if loose chippings can get in somewhere (brakes, exhaust - don't know) and make it sound like the death rattle of an old car. Stop, reverse a bit (presumably they fall out?) and all's well. Happened three times to me (and once to a very worried wife!!) so far and each time there were recent chippings on the roads used.
Could be something else but sounds quite horrendous when it's there - but goes away just as easily.
