Right Jamie, Stop mingeing aboutand fit the other spring. Start low and then work up. Then come back and tell us how good your set up is. (Don't go mad or past 1.4 bar @ Red line.)
You just keep unscrewing it until it comes out. Be careful when you think its about to come out that you dont drop anything.
I haven't seen this piece Jamie but theres a chance that it could be able to come apart without fully removing the screws. Some pieces of kit have captured screws that are like that so you don't lose them. I'd try backing out all the screws till they stop and get a knife/screwdriver out and see if you can prize it open with a little persuasion.
Just thought bud![]()
Personally I'd get the EBC in and working, then take it to who mapped it and have them check it all out for you, get the actuator set right and the controller etc.
what happens if you clamp the actutor hose or disconnect it completely and drive (carefully)......... as this *should* be uncontrolled boost, but if its only 1.2bar max still its hardware
fella you scare me... you are messing with this and dont know the pipe which goes to your actuator?
Forget I suggested it... please get someone to do this for you who knows what they are doing. You risk engine damage otherwise.
follow the pipes to your actuator.. thats the simple bit.
Fiddling with this is potentially risky..
I have used my suggested method to diagnose control from hardware issues, and yes it would be "uncontrolled boost" aside from controlling the throttle, which is'nt hard.
but again, I suggest you ignore what I said if you are not sure what you are doing.
I thought Dave ran MBC in parallel with his N75 for a while to deal with the spike whilst he adjusted it and the sps settings to tweak his boost up
