MK2 20VT (Another one)
roly
midnightmotors.net
Jan 2, 2002
1,883
Midnight Motors Workshop
we don't mess about tris you should know that :)
we're using a 2000 model cupra as the doner, we will be fitting the pedal box as it will be running full hydraulic clutch setup and the dash aswell as it makes the conversion easier
roly
midnightmotors.net
Jan 2, 2002
1,883
couple more pics from today (sorry for the pants quality)
all the wiring loom is out and engine bay is now empty
tomorrow we're going to clean the engine bay up, mod the bulkhead for the hydraulic clutch and start fitting up the new loom and engine parts if time allows
empty looking interior
old engine verses new, nothing in it size wise
MK2 16v in kit form :cartman:
robbyd
is the 1.8 engine DBW?
what mods have you got to do to the bulk head?
roly
midnightmotors.net
Jan 2, 2002
1,883
the AYP is DBW
the mk2 16v runs a cable operated clutch so you have to cut 3 holes through the bulkhead next to the brake servo to fit the clutch master cylinder, you could use the 16v cable and change the mechanism on the 20vt gearbox but as we're going to the trouble of fitting everything else we're using the hydraulic setup aswell
this part we set about today but quickly found out the bulkhead on the gti 16v is different to the bulkhead on my 16v cupra sport :confused: (mine is flat next to the brake servo where as Martin's is raised so made fittment interesting) possibly because the gti runs air con, we had to relocated the clutch master cylinder lower down which then meant brake and clutch lines needed reworking
then to top it off the accelerator pedal mountings are also different between the two (again they wern't on mine :confused: ) so the 20vt pedal is going to have to be cut and welded to fit, or the 16v one reworked to incorporate a potentiometer bracket for the DBW
stressful day but all good fun :)
Martin M
www.midnightmotors.net
Nov 12, 2006
1,322
Kent
Bulkhead bashing was fun, apart for that i felt like a spare part!
Ben is Mr. Seat so he fixed it all up good!
Hope tuesday goes better.
robbyd
all sounds like good!
so if i put a 1.8 engine only in my mk2 cupra sport and kept my gti gearbox in there would i have to change the pedal box for a DBW set up?
Martin M
Nov 12, 2006
1,322
Kent
Finally got a dash sorted today and for a good price. Already fitted, but came across a problem with the front cross member...nothing's ever simple with my car!
Ben's got some pics so i will let him do the update for you!
roly
midnightmotors.net
Jan 2, 2002
1,883
Not a good day in the build then
i've had better days mate, today went a bit better but there's always something else to do, you wouldn't think a year could make so many differences between two body shells
depends what cupra sport your doing it to, the 8v box won't work as far as i know but the 16v one should bolt straight up as it almost he same externally as the 20vt box
you could modify the 16v pedal to accept the throttle pottentiometer (bit of cutting and welding) and use the original 16v pedal box, only really need to change to the 20vt pedal box if your going for full hydraulic setup
roly
midnightmotors.net
Jan 2, 2002
1,883
todays pics
after yesterdays findings i was ready for another suprise today and as expected i got it
after dropping the engine in we then found out that this 16v has a different front cross member to my 16v :confused: again :confused: im still to check part numbers to see what model it's from but it means the power steering pipework and secondary air pump won't fit on
we're going to get handy with the grinder tomorrow and see what we can come up with but ultimatly will be on the lookout for a 20vt cross member
on a plus side all the wiring loom is in aswell as the dashboard and i managed to knock up a bracket to hold the accelerator pedal correctly sos not all bad news
roly
midnightmotors.net
Jan 2, 2002
1,883
doner car cross member was bent, didn't look it but when compared to the 16v one was well out
got a replacement coming 2moz so should be back in business, bit more of a relaxed day today rebuilding selector mechanisms and just trial fitting some of the shiney bits
did managed to crank the engine over quickly and it fired up fine so that's a good sign
will be pulling out all the stops 2moz as it needs to be on the road by sunday night
