mk2 GTi brakes on mk3?
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
oooh not seen one - sorry mate
whats ya email ? (pm me if ya like) and ill flash a pic up now and send it
antnee
Thanks for the email Flapper.
For everyone else, I think if you have a 256mm setup then to change it to a 280mm setup you just need the caliper carriers/frame and bigger disks obviously
antnee
Nope, from EKTA drawings the calipers appear to be the same :D I will be moving to 280mm brakes when I have the money. You can get slotted and drilled 280mm disks for 70quid :)
antnee
Im really confused now, Ive been on some brake parts sites, disks for the 1.6 as per the sites are 20mm thick but the calipers are 13mm :confused:
Also the cupra calipers and disks are 22mm thick, so would new calipers be needed then?
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
that's the difference between solid and vented disks that the 1.6 has listed - what you need to do first is check what make / type / disk size that you have on the car to start with
239mm-(12mm solid or 20mm vented std)
girling 280 calipers
girling 280 carriers/frames
girling pads
280mm discs (22mm wide)
256/280 bearing carrier assy/stub axle
256mm-(20mm vented std)
girling 280 calipers (poss use 256 but tbc)
girling pads
bearing carrier/stub axle is not required as the standard 256mm one has the right mountings to match the 280mm calipers/frame
now although 256mm lucas calipers look the same they run a 2mm thinner disc than the 280mm and i believe the aperture is also smaller in the caliper.
I have been told the 256 calipers are wide enough to clear the wider 280 discs but every frame/carrier kit i have had my hands on so far has come complete with calipers anyway and i keep forgetting to try the old ones on there but for 1mm i would imagine it was the case.
although not set in stone mk2 280mm gti calipers were painted red as standard so safe to say red ones are indeed 280mm but as anyone can paint a caliper anytime don't rely on it being true.
and be careful selecting kits as the 256/280 to look at by eye looks the same it's the location of the mountings on the carriers/frames that makes all the difference diameter wise
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
if you can hang on a bit i might have an idea for a cheap 4 pot conversion ;)
literally twice as heavy as and not as top notch as brembo's but will be different for sure but i reckon could work out same/cheaper than sourcing 280's
antnee
Just had a thought, which I had neglected before, will 280mm brakes fit under 15" wheels?
Daymo
Low and Slow..
Jul 22, 2008
428
Scarborough/Sheffield
i'd be interested in that cheap 4 pot conversion, how much work would be needed and can you get a rough price up flapper?? will it fit underneath the standard cupra alloys also??
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
got some standard wheels back on mine now so will be looking for spare time and a ramp to run a test or two as soon as i can get a window to run a test properly
got mine back to working properly at last too - check ALL round ya brake hoses btw ;)
just an idea at present and passed over with current weather etc but promise it ill get on it and try it out
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
basing this on standard lucas 280x22mm Gti Brakes as a base
quick update on weight wise apparently same shipping as std caliper without slider frame but as yet i would like to weigh myself to confirm that so not far off there
standard caliper is single sliding 54mm piston / test one is 4x40mm
couple of pages later have worked out it is only approx 10% more piston area compared to std so not much but an improvement for testing to verify at least ( 4581.04 > 5027.20 )
disc size is 280 discs as the base as above at moment but fitting will tell me if larger can be used as i reckon the offset on 305mm might be better suited to this one
just to note as i haven't measured it yet but upgrading brakes you will have to think about standard master cylinder also and rear drums/discs etc
larger piston area will mean more power but a longer pedal to some degree
anyway - collecting a few parts some needed some to play and try so hopefully weekend ill get some time to play
