Guest, 🚨New Stock alert: Premium CUPRA valve caps now available in the store 👉 Order now from the merchandise store
im sure I had this fault code back along, possible maf sensor on its way out?
do you have a standard air box? any lights on the dash come up?
how does the car drive?........****
have you done another scan on vag com since the light came on the dash?
I would say it is your maf, do you have a forge recirc valve or std bosch?
you could unplug the maf plug and drive it for a very short distance, if it flies then it is your maf sensor, re plug it in and dont drive it far until you have a new one, from the dealer or GSF
it will tell you if it is the maf, trust me I did this on my car, do a search on various threads on here, if you dont want to do this you could do a log through vag com to measure the maf g/s reading, block 018 iirc
Im sure its your maf fella, all the symptoms are there
Biglad; have a read of this I found, should give you a good understanding, hope it helps
http://communityhosting.net/tdiclub/index.php/Mass_Airflow_Sensor
I had this problem when the jubilee clip broke around the DV. Check all TIP connections and vac hoses.
get back to us
did you unplug the maf? is it driving fine with it plugged in now? the light on the dash has gone out....![]()
just keep an eye on it, surprised that the light went out but it might come back......
