  • Total voters
    989
Mine had 42 psi!! Just dropped to 32psi in the front and 29 in the rear.
Is the 32 and 29 just a guess? That's MUCH lower than recommended. The white label with the tyre pressure settings is inside the passengers side door.
That sounds high - are you looking at the fully loaded pressures?
No, those are the normal load pressures listed on the label on the door-frame. I was quite surprised because it was quite an increase from the 32 when the car was delivered last week. The fully loaded pressures are over 40.
Mine were set midway between normal load and high load and I'll just keep them at that. 40 on the front and 38 on the rears.
My my19 has 39 in the front and the 35 in the back,checked them after reading this and there was 42 all round.seems to grip a lot better now
Are the normal speakers good enough? I’m disappointed that they’ve removed Seat Sound
Reactions: Mystery290
Anybody else have the ‘racetrack’ setup displayed...
Well my old 280 is very special, it only has the two options but for two different wheel sizes.
I use 2 bar (front and rear) for track days
My ST 300 4drive has arrived at the dealers.. Unfortunately it's covered by four inches of snow currently, so no pictures. I shall be getting it early January, because of taxation changes (yet again in Finland) .. Well at least there's plenty of time to get the engine heater installed and get it pretty and cleaned.
Oh, and this one's my fourth Leon Cupra overall:
2009 240hp Cupra 1P
2014 280hp Cupra 5F
2016 290hp Cupra ST 5F8
2019 300hp Cupra ST 4Drive 5F8
Got a call from my dealer today that my Midnicht Black ST 300 4Drive is due to arrive on Tuesday. It'll get a fuel operated engine and inroom warmer fitted and probably I'll get a Ceramic coating on it also. Maybe I'll get my hands on it on January 2nd.. It has the digital cockpit, Beats audio, the cup seats and parking sensors front and back. Can't wait.
Hope so, I ordered mine in October but sure the exhaust will keep me acousticaly entertained :))) I will try & get the sound actuator turned off though. I posted earlier I have emailed Seat with my feedback on sound system upgrade no longer being available. Sure the normal setup will be ok. That is my gripe, the Cupra should be more than just OK. Hopefully someone at Seat S.A will get a boot up the rear & Beats or SS will become standard or optional once again.
I've put down a deposit on a non-Lux MY19 model, but for a tiny bit more I can get the Lux pack. I'm unsure of the leather seats - I'm guessing they don't hold you as well as the alcantara seats but is there much of a difference?
