F8 CMR
88
South Shields
last week i took my car to the dealers as when i came to put the near side rear window up it was goign 3/4 of the way up then back down doing this several times untill it eventually went up anyway the said there was a coding problem therefore re coded it and it seemed to work fine. Untill this morning when it started to do it again! has this happened to anyone else jw what the outcome was?
cheers
It sounds like the window is sticking and the anti-squeeze is kicking in. Normaly the side seals need a bit of lubricant to help the window slide more freely. I cant remeber what people have used but if you do a search on here others have had a problem.
My rear window also is problematic to see the least. When it's going down, it jumps up and down, like it wobbles. It's also not sealing properly as there is always condensation in the bottom corner, need to get it sorted but it's finding then time :(
Danny.
